I made a mistake
Re: I made a mistake
Postby GeoffSmith » Tue 04.05.2021, 10:49
Also the NA ECU circuit diagram is here:
http://wikilec.com/images/8/83/MJ25-03_ ... 8NA%29.gif
Postby GeoffSmith » Tue 04.05.2021, 10:51
Rambo wrote:It does say ECM (turbo) though
It's only the turbo that has the sense line connected back from the fuel pump (I believe).
Postby Rambo » Tue 04.05.2021, 10:53
Don't ask me. I've got no electrical/electronics knowledge :wink:
Postby dapinky » Tue 04.05.2021, 11:11
Ah,
I fully understood the 'atmo' term, but (in my mind) disregarded it when the conversation went to ECUs....
First, the ECU for an NA is quite different to the ECU for a turbo - it is far more basic inside - whilst the NA one cannot work with a turbo, I don't know if they would work the other way round - Geoff :poke:
Anyway, I do know that leaving the ignition switched on on my old cars (1970's) would cause the coil to get very hot, and eventually fail......
..... is it a possibility that the NA ECU would allow current to still go to the coil in these circumstances, and cause a failure there??? I really have little knowledge of the system on an NA, and suggest it purely because it was a common failure on a Mk3 Cortina!
Postby tangara » Tue 04.05.2021, 12:50
It was my first thought: ignition but as I turn ignition switch on there are sparks on the plugs.
I have the fuel pump connection diagram and NO +12v with white and light green incoming signal for the relay.
Will have a look at fuse A5 and M relay (
tangara
Postby Saltire » Tue 04.05.2021, 13:44
dapinky wrote:. . . purely because it was a common failure on a Mk3 Cortina!
In my experience pretty much everything was a common failure on a Mk3 Cortina :shock:
Postby tangara » Tue 04.05.2021, 14:42
GOT IT ! IT runs
relay M defect ......
thank you to all of you for the help
Thierry
tangara
Postby Rambo » Tue 04.05.2021, 15:13
Well done Thierry :smt023
Postby Saltire » Tue 04.05.2021, 16:03
tangara wrote:GOT IT ! IT runs
Thierry
Great news! :clap:
