Air-con not working!
Postby joop » Tue 26.06.2007, 09:59
My Elan air-con doesn't blow cool air anymore, it just blow normal temperature even if I've pressed the air-con buttom. This is really uncomfortable when I'm driving in 30c hot summer. If I don't fix this problem, my leather seat will be gone soon with my sweat.
Please help!
joop
Postby theelanman » Tue 26.06.2007, 11:39
get the system 're gassed'.......sounds like you coolant has expired...
needs topping up
cheers
G
Postby John Tsakas » Tue 31.07.2007, 10:44
hello
Look if your compresser is good. Do you have freon ?
yesterday i fix my a/c i change the compresser and its perfect
John Tsakas
hello
John Tsakas
Re: Air-con not working!
Postby nitroman » Sat 20.09.2008, 01:30
My A/C started alternating between working then not working yesterday. I threw it around in my head last night & decided to check the pressue 1st. Sure enough, it was right on the low-border of acceptable. Charged it up to the top of what's considered normal and it works GREAT! Did find a slow leak & am in the process of ordering that part. However, how bad/quick must a leak be B4 deciding to open the system? As the ozone-layer quivers before me, lest I unlease 90lbs of R12 on its ass, I'm not overly concerned.
-The Freon King
nitroman
Users browsing this forum: John Tsakas and 3 guests
