INJECTORS SIMILAR TO STOCK? OTHER BRAND?
Postby nissias » Mon 31.12.2007, 01:42
Anyone has an idea for similar compatible injectors that I can buy either from Europe or the US?
I believe the ones advised by a few people in here from RC Engineering are 550cc and this is an upgrade for people using larger turbos, 3-bar map sensors, and other fuel controls.
As far as I know the stock ones are 325cc and I want to continue using the same size with my ecu programs from Alan.
So if anyone has the knowledge or experience to let me know what to look for that would be great.
Nik.
nissias
Postby tweetdriver63 » Mon 31.12.2007, 02:02
I would guess injectors for the Isuzu Impulse Turbo, same year, same engine, would be right, but I can't prove it. Everything else in or attached to the engine seems to be the same, except the Turbo itself. I know the alternator, AC compressor, belts, pulleys, thermostat, intake plenum, etc, pretty much everything is the same.
Does anybody know for sure?
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby tigerdog » Sun 13.01.2008, 00:44
Stock injectors are (I think) 320cc units. RC Engineering has off-the-shelf injectors of that size. You could email them with the stock part info and see if they have a replacement. The rotary-valve injectors are supposed to last longer and be more accurate than the stock pintle-type, too.
