Cam belt replacement parts
Postby Colinr » Fri 14.09.2012, 19:17
Can anyone recommend a supplier for parts? I've just acquired my first M100and want to play safe and change the cam belt, tensioners etc.
thanks in advance,......
Colinr
Re: Cam belt replacement parts
Postby Rice crispy » Sat 15.09.2012, 10:58
Rock auto in USA is cheapest, sjs sportscars or paul mattey in uk
Have a search as there may be some discount codes on here for rock
Rice crispy
Postby inkitin » Sat 15.09.2012, 15:23
RockAuto discount code 104847558619856 will expire on September 23, 2012
91 SE Calypso Red
inkitin
Postby madbilly » Thu 20.09.2012, 11:38
I think you can get the belts from Camskill in the UK and you could ask them about the pulleys as well but I think you'll have to get them from Rock Auto.
madbilly
Postby Stef » Sat 29.12.2012, 20:31
Also in need of a new set of belts and have a fresh code that expires TOMORROW!
Can anyone please advise on what I need to order as I cannot seem to find the belts in their drop down lists.
Anyone else also interested if you'd like me to order more than one set??
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby Brit-Car-Nut » Sat 29.12.2012, 20:38
Stef wrote:Also in need of a new set of belts and have a fresh code that expires TOMORROW!
Stef:
Use the Rock Auto Isuzu Impulse (Turbo) listing for the engine parts: Cam Timing Belt, Idler, Tensioner, Water Pump are a good starting point.
The discount code 119844263686183 expires on Jan 6 and they will issue a new one before that.
Merry Christmas and Happy New Year - Glad to see you replaced Blipi and were unscathed in the loss.
Postby Stef » Sat 29.12.2012, 20:45
Magic!
Thanks for such a swift response! :cheers:
Stef
Postby Stef » Sat 29.12.2012, 20:49
Hoping I'm in the right place now, however, which one should I be after??
http://www.rockauto.com/catalog/raframecatalog.php
Edit - the link doesn't take to my search picks. Isuzu, 1990 Impulse, 1.6ltr, engine, Timing belt component kit.
Stef
Postby inkitin » Sat 29.12.2012, 21:06
Stef
Choose:
ISUZU
Next:
1991
Next:
IMPULSE
Next:
1.6L L4 Turbocharged
Next:
ENGINE
Next:
Timing Belt Component Kit
For simplicity I bought the "DAYCO Part # WP169K1A" kit
Also, you only need one other person to join in to make the P&P significantly cheaper. Three or more people gives only a marginal saving.
91 SE Calypso Red
inkitin
Postby Stef » Sat 29.12.2012, 21:09
Sweet!
Thanks again.
Any takers??
Stef
Postby Brit-Car-Nut » Sat 29.12.2012, 22:29
If you don't mind doing it piece by piece, looking at the US site, you can save $30.00 by getting a 41053 water pump, 1261017 Timing Belt and 84103 Tensioner / idler kit. Even more if you look at the 95169k1 Dayco kit for the belt and widgets and then get the water pump.
No reason to pay any more than necessary. All of the above are from good, reliable suppliers.
Postby baldyash » Sun 30.12.2012, 11:17
Stef --You have PM
baldyash
Postby Stef » Sun 30.12.2012, 19:56
OK. Just need final clarification here as I really don't understand what I'm buying :roll:
Here is what Baldydash kindly PM'd me:
Kit DAYCO Part # WP169K1A £64.96
Belt Alternator GATES Part # K040270 £5.48
Belt PAS no A/C GATES Part # K060380 £5.09
Different to what Brit-Car-nut recommends...
From what I can see, surely the Dayco kit 95169K1 supplies all I need for £23.38 ??
Bound to be corrected on my assumption but please feel free as once finalised I can then order! :-D
Thanks for entertaining my remedial engine knowledge and helping me out... again!
Stef
Postby Brit-Car-Nut » Sun 30.12.2012, 20:27
Stef wrote:OK. Just need final clarification here as I really don't understand what I'm buying :roll:
Dayco kit 95169K1 is the timing belt, idler and tensioner. If that is all you plan to do then that is all you need. Most people replace the water pump at the same time as you need to do the same amount of work to get to it as it you need to get to the timing belt. It shouldn't add much of nothing to the total labour charge to get it replaced at the same time.
The other belts are usually replaced as needed and don't require tearing the apart the r/s wheel arch to replace them. If your belts are squealing, then replace them too otherwise, it is your decision what extra maintenance you want to get done.
Postby epipete » Sun 30.12.2012, 21:21
Can we please clarify, finally:
Dayco kit 95169K1 equals the timing belt, idler and tensioner
Whereas
Dayco kit # WP169K1A equals what?
Postby baldyash » Sun 30.12.2012, 21:39
Dayco kit # WP169K1A equals what?---its the same but also includes a waterpump
http://www.rockauto.com/catalog/moreinf ... cc=1176173
baldyash
Postby Stef » Sun 30.12.2012, 21:46
So the Dayco kit 95169K1 at £23.38 is what I need but will need a seperate water pump belt?? Which is what order number?
Seems much cheaper than Brit-Car-Nuts list.
Still all very confusing though and glad I'm not the only one! I think I recall my last order being less than £50.
Stef
Postby Brit-Car-Nut » Sun 30.12.2012, 22:19
Stef wrote:So the Dayco kit 95169K1 at £23.38 is what I need but will need a seperate water pump belt?? Which is what order number?
Not a water pump belt, a WATER PUMP.
The water pump is driven by the timing belt.
I suggested Dayco kit 95169K1 @ £23.38 + water pump 41053 @ £18.49 = £41.87 everyone else pushed Kit DAYCO Part # WP169K1A £64.96 which is the same belt parts but includes the water pump.
You really should let your mechanic TELL you what they want you to get so you get the correct parts the first time.
Postby inkitin » Sun 30.12.2012, 22:26
inkitin wrote:For simplicity I bought the "DAYCO Part # WP169K1A" kit
Seems like I never said a truer word!! :lol:
91 SE Calypso Red
inkitin
Postby Brit-Car-Nut » Sun 30.12.2012, 22:41
£23.00 extra just to avoid ordering two items instead of one? It sounds like Stef doesn't want to replace the water pump, so she will spend £23.38 for the timing (cam) belt "kit" and that is all she needs. If she wants to replace the water pump, then order the cheap Dayco kit + the GATES water pump and still save a lot. It really can't be made more simple, just more expensive. :D
