cas vibrating.
cas vibrating.
Postby harvey » Sun 25.11.2012, 18:32
Hi Can you help, I have recently been experiencing missfiring problems under load, so have replaced the ignition leads this has helped but i still need to take her for a spin on a long quiet road to confirm all is well. however I have noticed there is a vibrating sound coming out of the plastic cover on the CAS is this common or is something wrong going on in there?
Harvey
Any fool can make things complicated, but it takes a genius to make things simple.
harvey
Re: cas vibrating.
Postby DeanG » Sun 25.11.2012, 22:35
As I understand it the bearings can go bad, the mechanism can hit.
DeanG
Re: cas vibrating.
Postby harvey » Sat 01.12.2012, 16:17
does anybody know if bearings can be replaced? or is it a new unit? if so are these still available?
harvey
Re: cas vibrating.
Postby DeanG » Sun 02.12.2012, 21:46
The bearings can be replaced. I think mine need to be done. I have a built up spare CAS that needs to go in. Then I can rebuild at my leisure for the swap.
DeanG
Re: cas vibrating.
Postby epipete » Sun 02.12.2012, 22:14
harvey wrote:does anybody know if bearings can be replaced? or is it a new unit? if so are these still available?
And from where?
Re: cas vibrating.
Postby Brit-Car-Nut » Sun 02.12.2012, 23:13
Re: cas vibrating.
Postby harvey » Wed 02.01.2013, 20:05
just to update, I took the plastic cover off and the noise disappeared, on further inspection there is some scoring to the inside of the plastic shield, refitted it and so far its been good, my guess is it may be warped.
harvey
