Coolant Pump Impeller Housing
Postby superbad » Thu 04.07.2013, 02:41
So I replaced my recirculating coolant pump a few years ago, and since it was the Bosch unit, the impeller housing was different, so I put the old housing on the new pump and all was good. Until this afternoon, when the old plastic housing failed and dumped all my coolant out. What's the latest on these pumps? Is one currently available with the correct outlet orientation on the housing?
superbad
Re: Coolant Pump Impeller Housing
Postby Jeemy » Thu 04.07.2013, 11:35
I bought the Johnson CM30P7-1. Are something like £90 new or pop up on eBay second-hand quite a bit, I got for £36.
It looks exactly the same as the original (without being able to compare in person); and I know some others have fitted them, as regards mounting to the car I have not looked into this yet. But hopefully that is helpful to you.
T: 0800 084 3084
M: 07391 295 146
Jeemy
