Brit-Car-Nut wrote:http://forum.lotuselancentral.com/viewtopic.php?f=4&t=22356
dapinky wrote:
Failing that, just pushing 2 pins into the 2 holes in the face of the fitting will depress the flange inside and slide the fitting off, without bothering with a tool at all - it isn't hard to work out, and will save time/money - it only needs a gentle pressure to release the internal grip, then slide the fitting off - replacement is just a case of push it on until the internal collar clicks into place.
Much easier. I used two small jewellery screwdrivers, you need flexible fingers and preferably 3 hands but it is simple enough.
dapinky wrote:Failing that, just pushing 2 pins into the 2 holes in the face of the fitting will depress the flange inside and slide the fitting off, without bothering with a tool at all - it isn't hard to work out, and will save time/money - it only needs a gentle pressure to release the internal grip, then slide the fitting off - replacement is just a case of push it on until the internal collar clicks into place.
BigErch wrote:unfortunately I need the car for Sunday so i won't get these in time
BigErch wrote:I'm driving the GT3 tomorrow and Stevos taking the Elan - is this wise?![]()
