with John,
My thoughts would be NOT to block any radiators. The various 'radiators' IIRC are (from inside the cabin)
Left hand = the Intercooler which supply's cold air to the turbo. Any alteration to the flow of air will be detrimental to boost and may damage the turbo
Right hand = the Oil Cooler, again the engine is engineered to run very hot so interfering with the oil cooling capacity is an engine killing measure
Neither of these is likely to improve cabin temperature efficiency.
Finally, the Central Radiator is for engine coolant which, again, is critical to maintaining engine integrity and so I should not tamper with it.
The coolant is allowed in to the Heater Matrix via a valve (as John mentioned above), this can be located between the coolant header tank and the plenum (from this you should find two pipes leading through the bulkhead (to the matrix)). If you disconnect these pipes you can flush the matrix out and check the condition of the valve. This will determine if a blockage is the cause.
- image.jpg (44.05 KiB) Viewed 4168 times
The other reason for lack of heat is that various vacuum pipes are used to activate various settings on the heater flaps (in addition to activating the aforementioned valve). You will need to check that you have an appropriate vacuum; but in the first instance (while I dig out the proper thread
) if you run the engine to warm (heater set to cold) and check the temp of the two pipes leading through the bulkhead they should be cold as the cold setting operates a vacuum which closes the valve, get someone to operate the heater to hot and watch to see of the Valve automatically opens. Either way you can now open the valve manually (if setting to hot didn't work) and you should feel the pipes getting warm (and then hot) as water flows through!
Give it a try and shout if you need more info.
Pete
Here is a useful thread:
viewtopic.php?f=37&t=22758&p=286929&hilit=Matrix#p286929And another:
viewtopic.php?f=37&t=21666&p=272723#p272723
