Rob,
I've done about 6 Elan ones now, and always used rattle cans (except for one, where I tried 2-Pak due to the colour requirement).....
......mixed results - always dependant on the paint used.
Main thing is to follow the instructions for individual brands, and prep the surface properly.
(once it's clean, it'll fit in the dishwasher when the missus is out
If you're spraying slightly downwards, there is no need to mask it up underneath - I just wrap a bit of tape round the breather pipe, remove the breather valve/grommet, stand it on a couple bits of 2x2 timber and away you go (on the workbench / newspaper - not still in the kitchen
As Jamie says, removal of the ISUZU & 2 extra lumps of metal is easy with an angle grinder/sander - there will be a small hole left at the site of one lug, but chamical metal or even simple bodyfiller will sort that out - not much needed, but it does tidy it up a lot.
If you are using VHT paint, you *may* need to bake it in the oven afterwards unless it's going straight back on the car and engine run to get warm - I found that the paint is a bit 'soft' straight away, and i either bake it for half an hour (if wife is still shopping!), leave it a few days, or heat with a hot-air gun. Maybe I'm just a clumsy git, but if I try and fit it back to the car before it hardens, I leave fingerprints on it.... not always a problem as the paint will still 'flow' a bit as it cures. (anyway, I've got spare ones to work on to keep the car on the road).
Use a suitable primer (for Aluminium) - it will make a big difference.
Lastly, 2-Pak is going to be the best, but is not worthwhile in small quantities. The best rattle-can paint I tried was a Plasti-kote one (but there are so many ranges of that stuff these days) - and a perfect match for Calypso red.
Jamie,
I noticed when I got back from Brands Hatch that the crackle-black on mine has started to lift just in a small area just by where it would get hotest (near the exhaust manifold/turbo) - it is still intact, but seems to have 'shrunk' on the radius of the corner and lifted from the metal. Have you ever had such reaction with yours?
It isn't noticeable at all, but i caught it with a finger whilst wiping up spilt oil from an oil change. Careful examination shows it all still looks good, but will no doubt spread and eventually flake off.
Do you recall what brand of paint you used? I think I'll do a spare one and swap them over.
- lifting cracle black.jpg (59.29 KiB) Viewed 13905 times
