starter motor
starter motor
Postby steven » Fri 02.09.2016, 15:13
Does anyone know how to reach the upper bolt of the starter motor?
Steven
steven
Re: starter motor
Postby Candles » Fri 02.09.2016, 20:02
Yes!
Prongeron off, car raised securely, arm yourself with a 14mm ratchet ring spanner that has been doctored by grinding off the open-spanner end. This will allow you just enough room to get 1 click at a time from the ratchet. Pain in the arse. I think I had the exhaust off as well!
I used to have a write up - I'll have a search.
Candles
Re: starter motor
Postby Candles » Fri 02.09.2016, 20:08
Starter Motor Removal, Refitting & Repair
After months of intermittent clicking, the starter finally decided to no longer turn the engine. Time for removal!
Prior to following the workshop manual, the first thing to do is get the car up on something. The wheels need not be free but it helps for the driveshafts to be more out of the way. The higher the better (to a point!) as your arms will be straighter hence making it easier to reach in to the constricted area.
Next, disconnect the battery. Definitely do this as otherwise you will have a live +ve floating around the engine bay when you work on it!!
Then, to provide access to the rear of the engine, the crossmember under the engine has to be removed; That is this thing, when viewed from the top:
Arm yourself with a 19mm socket on a big handle, a 19mm ring spanner and a 8mm socket and ratchet handle. Start at the radiator end and disconnect the LH fan and free the wire from the clip. Then undo the 3 setscrews that hold the front of the crossmember in place. Noting the placement of the spacing washers, remove the engine damper. At the rear, on each side remove the 2 rearmost bolts and then the two bolts (+nuts) towards the front. Finally remove the nut on each side at the front. Withdraw the crossmember from under the car.
Now undo the exhaust from the bottom of the downpipe and loosen the flexible joint. Remove the oil filter to improve access.
Disconnect the solenoid leads by pressing the side of the weatherproof connector and pulling out (top right of photo above) then disconnect the power supply leads from the terminal (middle right of motor body).
Now here comes the hard bit. In the manual it simply states; "Remove the two mounting bolts." Ha ha! This took me hours!
This is the view of my Elan's filthy underside looking straight up. The front of the car is the bottom of the picture and the exhaust is the pipe on the right. I have scribbled a red line roughly where the body of the motor is when installed. The lower bolt is no problem to get to but the upper bolt is above and behind the motor, out of sight. I tried a socket but although I could get it onto the bolt, I couldn't get an extension in behind the motor to turn it due to the oil pressure transducer (black rubbery thing) being in the way. I managed to turn the bolt using a 14mm ring spanner, but less than 1 flat, so I couldn't reposition it to turn the bolt anymore. I ended up buying a 14mm ratchet-ring spanner from Halfords and using that, initially intact. I was moving it 1 click (~5 degrees!) each time due to the restricted access, so after much swearing, I butchered the spanner to the photo in the next post.
I repositioned it and it worked like a dream. I took the motor out and withdrew it from behind the engine. This is the bit where you need to just push the exhaust slightly out of the way. If anyone has to do this job, you will save hours by having a spanner like this. Drop me an email and I'll send it to you as I can't bear to think of anyone having to go through the pain that I did!
Once removed, I bench tested the motor and discovered that the solenoid fires but without switching on the motor. At the time I managed to source a replacement unit which I fitted.
Refitting the motor was easy. I located the top mounting bolt by hand then tightened with the ratchet ring-spanner. I torqued the bottom one up properly and then felt the torque with the ratchet spanner to get an approximate tightness for the top one as there was no way of getting the torque wrench in there. Reassembling the rest was literally the reverse of removal, with a bit of threadlock and a slight cleanup for the various chassis crossmember bolts.
When I got around to fixing the old motor, I first took off the end cover by removing the three screws marked with an X:
Underneath was revealed the solenoid plunger and contactor mechanism:
On the left and right are the output to the motor (blue) and input (removed) respectively. The black wire is the signal from the keyswitch to fire the solenoid.
I removed the old contacts to reveal the highly worn surfaces (marked with arrow)
I then obtained shiny new ones from a local starter and alternator specialist (name and address available if required). He mentioned that the unit is very common to many applications and had the contacts 'on the shelf.' Make: NipponDenso Motor model: 8944410871 Serial: 128000-4571
I fitted the new contacts and cleaned up the central copper contact ring on the solenoid armature. On reassembly and test it worked perfectly.
Candles
Re: starter motor
Postby Candles » Fri 02.09.2016, 20:10
Candles
Re: starter motor
Postby steven » Tue 20.09.2016, 16:01
How to remove the upper bolt?
It is indeed a nightmare to get that out.
Candles way did not work out for me, I could not find the bolt (yes with my finger tips!) but could not get a spanner on it.
I finished eventually by taking the starter motor apart in situ.
Remove the two long 10 mm. bolts, then you can "rather easily"(Lotus wise) reach the upper bolt.
At that time Candles spanner, was agreat help.
Reinstalling goes the same way, but make sure that you prevent the anchor from falling out of the housing. I did that with ducktape.
All together it is a hell of a job.
:banghead:
Anyway Candles, thanks for your help
steven
Re: starter motor
Postby steven » Thu 11.05.2017, 16:48
If you use my way, do not thighten the long 10 mm. bolts to fast.
I did that and the startermotor had problems in turning around: too much friction!!
steven
