Fan thermal switch
Fan thermal switch
Postby Rmiddleton » Tue 20.09.2016, 22:37
Hey everyone this is my first day on the sight I own a 1992 lotus elan witch I love , but the fan thermal switch is gone ( the temp sensor that turn on the fan and the circulation pump) does anyone know where to find this in North America , is there a GM one that will work or does anyone know at what temperature it activates at. :P
Ricky M
Rmiddleton
Re: Fan thermal switch
Postby Brit-Car-Nut » Wed 21.09.2016, 00:32
Welcome to LEC
Where are you located?
The stock switch turns on at 235 degrees F. The stock thermostat is 195 degrees F.
I sent you an email with a link to a common replacement option.
Postby Peter D » Thu 22.09.2016, 00:07
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
Peter D
Postby Rambo » Thu 22.09.2016, 09:44
Peter D wrote:http://www.rodneydickman.com
I'd second that Peter
I have a RD low temp fan switch in my NMY
Back in 2009 it cost $27 for the switch (185/190°), $12.95 for a pigtail and $7 for shipping to the UK. No doubt prices are up a bit these days but well worth it
Postby danbrown100 » Thu 22.09.2016, 18:31
I just looked on his site and the fan switches are in the close out section, marked down to $12 - at that price everyone can afford to buy two! :D
http://rodneydickman.com/catalog/produc ... cts_id=349
Milford PA - 70 miles NE of NYC
1991 Elan SE, 54k miles, needs some TLC
1995 Audi A6 Avant, will outlive all of us!
1973 BMW 2002 Touring, currently off the road
danbrown100
Postby GeoffSmith » Thu 22.09.2016, 19:53
Brit-Car-Nut wrote:The stock switch turns on at 235 degrees F. The stock thermostat is 195 degrees F.
I think you're quoting Fiero specs from Dickman as he talks about replacing the 195°F (90°C) 'stat with one of 180°F (82°C) when using his low temperature fan switch: The Elan 'stat should already be 82°C.
From all the ElanScan logs I've seen, our fan switch usually turns on at 105-110°C (220-230°F) and the thermostat opens at 80-85°C (175-185°F).
Postby Rmiddleton » Sat 05.11.2016, 16:09
Brit-Car-Nut wrote:Welcome to LEC
I live in Fort saint John BC Canada, I find this sight quite helpful.
Rmiddleton
Postby robertverhey » Tue 08.11.2016, 23:42
If you've tested the switch and it's faulty, all well and good. But worth checking the earth lead onto the rad housing first, a poor connection here will stop the fans kicking in as well.
robertverhey
Postby Brit-Car-Nut » Wed 09.11.2016, 00:08
Yeah, SORRY. In the early '90s they drummed it into our heads that all thermostats were going to 195 to better meet emission requirements.
I am amazed Lotus didn't do that too since all it does is get the engine to temp sooner and it improves the heater a bit.
Postby kevinrooney » Thu 26.01.2017, 10:48
Rock autos list a number of thermal switches for
 ISUZU    1991    IMPULSE    1.6L L4 Turbocharged    Cooling System    Temperature Sender / Sensor.
there are a number of very reasonably priced options for the temperature sensor for the EMU and the temperature gauge .
I don't know if anyone has had any experience with these sensors . are they the correct resistance for the Lotus setup?
Previously fitted a nonstandard temperature gauge sensor which indicated the gauge reading to high rather than to low which was a bit alarming.(ended up cleaning up the contacts and refitting the original).
thy don't seem to provide one for the fan thermal switch .
kevinrooney
Users browsing this forum: AhrefsBot and 1 guest
