How do you get this water pump bolt out?
Postby atikovi » Sat 05.11.2016, 19:05
Can't get a socket on it because that bracket is in the way. Can't get a box wrench on it. Dare I try an open end wrench and maybe rounding the bolt head?
atikovi
Re: How do you get this water pump bolt out?
Postby atikovi » Sat 05.11.2016, 19:55
Took a chance with open ended wrench and got it loose. Then had to grind the wrench down to be able to turn the screw one flat at a time.
atikovi
Postby Steve A » Sat 05.11.2016, 20:48
atikovi wrote:Took a chance with open ended wrench and got it loose. Then had to grind the wrench down to be able to turn the screw one flat at a time.
Sometimes you have to make your own "special" tools :wink:
Postby lotusflasherman » Sat 05.11.2016, 20:53
A shallow 3/8" drive socket with a 'wobble' extension bar will get to it without any problems. Some of my special tools are 'wobble bars' ground to provide some extra wobble... :lol:
