Diameter vacuum lines?
Postby HJ2 » Tue 03.04.2018, 10:35
Dear colleagues,
As there is more and more evidence of a vacuum leak, I prepare to replace all the vacuum lines with Samco ones.
As i need to order the lines (no shop around) I was wondering if anyone knows the internal diameter of the vacuum lines, and if they are all the same diameter?
(I'm not at the car currently)
Re: Diameter vacuum lines?
Postby GeoffSmith » Tue 03.04.2018, 13:18
I used 5mm to replace the line to the reservoir HJ: And it was as cheap as chips!
Postby HJ2 » Tue 03.04.2018, 13:31
Postage 20 GBP! :shock:
But it was a good starting point to find replacment, thanks Geoff.
I just ordered 5 meters 5mm hose.
Postby Steve A » Tue 03.04.2018, 13:46
HJ2 wrote:Postage 20 GBP! :shock:
I could always post some to you when I order mine :D
Postby HJ2 » Tue 03.04.2018, 13:49
Thanks Steve!
However there are many suppliers now that i know the correct size.
So I ordered somewhere else just now :P
Postby Rusty Wishbone » Tue 03.04.2018, 23:19
I've just placed an order too. A couple of my vacuum lines leading to a Denso component (I've no idea what it is) on the near side inner wing are pretty perished, and my idle is not stable. Hopefully, this will be an easy fix.
Rusty Wishbone
Postby HJ2 » Wed 04.04.2018, 05:45
You mean the vacuum reservoir?
Postby Rusty Wishbone » Wed 04.04.2018, 22:59
No. It is the thingy between the near side headlamp motor and the big air pipe leading air into the plenum.
Rusty Wishbone
Postby Brit-Car-Nut » Thu 05.04.2018, 06:07
Is it in this picture?
Click for larger view
Postby HJ2 » Sat 14.04.2018, 13:01
I'm at it now, but hose 20 is NOT 5mm :(
Hose 2 fell right off the reservoir! :shock:
