Radiator bypass pipe leak.
Postby BeanBug » Sat 25.08.2018, 05:27
Hi All,
Need some advise. My radiator bypass pipe (RBP) is disintegrating from the inside out and causing coolant to leak. I am unable to find a replacement, and the local shops are having problems replicating the pipe due to the flare fitting on the o-ring end.
Could I create a thread in the hole that the RBP goes attach a stainless steel pipe fitting and replace the RBP with a hose? Or would the hose start disintegrating too due to the close proximity to the exhaust manifold and turbo?
Thanks,
Paul
BeanBug
Re: Radiator bypass pipe leak.
Postby John_W » Sat 25.08.2018, 09:54
It seems that there are others in the same boat. :(
It might be worth contacting Sinan:
viewtopic.php?f=134&t=26608
