Rubber Suspension Bushes and Bits
Postby Simon_P » Sat 11.06.2022, 15:21
The clear-out continues. Projects that have gone or aren't going to happen so I've go more of some things than I'm going to use. I could put these on eBay and watch the excitement but I thought LECers would be interested first.
All new and unused and plus P+P
Front Top Wishbone Bushes C100C6003F x4 £70
Lower rear raft bushes E100C6001F x2 £35
Upper raft mounting bush D100C6018F x4 £35 - you can cut these down (dapinky method) to use as front lower raft bushes.
Rear damper bushes A100D6020H £40 each
Damper top plate A100C0075F £50 each - The metal bit front and rear (no longer available)
Top Spring isolator £6 each - the rubber bit front and rear
Re: Rubber Suspension Bushes and Bits
Postby FunElan » Sat 11.06.2022, 19:36
hmm...tempted to buy the whole lot, I'm assuming sourcing these in the US won't be easy.
FunElan
Postby Simon_P » Thu 16.06.2022, 09:24
Front Top Wishbone Bushes C100C6003F x4 £70 SOLD
Lower rear raft bushes E100C6001F x2 £35 SOLD
Upper raft mounting bush D100C6018F x4 £35 - you can cut these down (dapinky method) to use as front lower raft bushes. On set sold I have another set.
Return to Elan Parts For Sale (new and used parts either OEM or exact replicas)
