rear bumper
rear bumper
Postby rushing » Mon 19.03.2007, 20:01
Hello all
how on earth do you remove the rear bumper please.where are the screws located.
thanks
rushing
Postby Paul.P » Mon 19.03.2007, 20:36
Rushing, you have to take out the rear carpet, the one that goes up to the rear lights, & you will see 4 nuts & 4 large washers, these need to be removed. Then there are the 5 or 6 normally rusty screws underneath that are screwed into rubber mounts ( think there called scrivetts ), which you normally have to grind off, or possibly get someone to push rubber out from the top whilst turning from underneath, thats how we did it anyway !
Postby paza1 » Mon 19.03.2007, 20:43
Manual 10.23A...... also see here http://www.lotuselancentral.com/forum/v ... ght=bumper
Hope this helps
Mark
Silver 1992 SE Turbo.
paza1
Postby Rogerf » Mon 19.03.2007, 23:50
Mine was also held on by a wing nut/bolt either side of bumper.This can be located by removing wheel arch mud flap!
Five bolts screw through into boot,can be seen when carpet is removed and four screws either end of valance.As Paul says these do take some removing.
Dave off this site as done some in stainless which you can purchase from him.
Roger
Rogerf
Postby paza1 » Tue 20.03.2007, 00:20
See here http://www.lotuselancentral.com/forum/v ... start=0for for a really well put together package of improved screws,washers and rawlnuts, all labelled up...excellent stuff,especially if you intend keeping your motor.
Mark
paza1
