Roof fit ?
Roof fit ?
Postby Steve A » Wed 09.04.2008, 00:15
:? Does a S2 hood fit a SE ?
What are the differences ?
roof
Postby John Tsakas » Wed 09.04.2008, 07:49
Hi Steve
I don't know the differense but mine is SE and it has S2 roof and
it fits perfect. I have no problem.
and you will tell me how do you know that?
When i bought it they told me that, and it was new.
The cars it is the same, why to have problem?
John Tsakas
Postby Dave Eds » Wed 09.04.2008, 08:05
Steve - got S2 roofs on mine. Roof comes down side windows slightly further to give better protection from water run-off. The key to cure leaks is still the seals though.
Postby Steve A » Wed 09.04.2008, 12:02
Thanks for that :)
My roof frame is starting to eat into the material, mainly when folded down, it's worn a 2inch split all of a sudden :shock:
I'm considering my options at the moment :?
There's an S2 hood on ebay hence my question,it's in Reading so it's not as though I can pop over and look at it :(
or there's the carhood wharehouse, ouch £££!
Postby Enright » Wed 09.04.2008, 12:43
Postby Steve A » Wed 09.04.2008, 16:36
:) Cheers Neil a good thread, I've nearly made my mind up that the hoods got to go, the back window is beyond polishing, and both corners are starting to split, but I'll give it some more thought. :wink:
Postby Dave Eds » Wed 09.04.2008, 17:16
Steve A wrote::) Cheers Neil a good thread, I've nearly made my mind up that the hoods got to go, the back window is beyond polishing, and both corners are starting to split, but I'll give it some more thought. :wink:
Elanman (Gareth) gave me a good tip he learnt from Trim Tech about folding down the roof/protecting from wear before closing stowage lid. Difficult to describe in words though. May be he will add some pics :wink:
Postby Steve A » Thu 10.04.2008, 17:03
:) The hoods getting one last chance, I've ordered the bostik 2402 , (also gives me time to save for a new one) .
New roof
Postby John Tsakas » Fri 11.04.2008, 11:23
New roof if you want and seals you can get in the below links
in good price i thing
You can choose and color if you want
http://www.topsonline.com/index.php?Dep ... odelID=637
http://www.carhood.com/lotus.htm
http://www.trim-technology.co.uk/
I hope to help
John Tsakas
