Pic of what nuts to remove roof mechanism?
Postby jecuk » Tue 20.01.2009, 18:00
I have read the wiki and posts here on the two b-post nuts to remove on each side top take the entire roof mechanism off. I can't work out which ones they are and was wondering if anyone has a picture that could highlight them for me. Don't really want to totally stuff the roof - just remove it while I have the hardtop fitted.
Forgive me for being dense!
'65 Fiat 500
'68 DB6
'08 Alpina B3
'09 Cayenne GTS
'10 F612
jecuk
Re: Pic of what nuts to remove roof mechanism?
Postby Gazza » Tue 20.01.2009, 18:30
If you lift the B-post caps, you will see 2 horizontal bolts about 4 inches long.
You need to remove these, then the roof will just lift off.
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Nige » Tue 20.01.2009, 21:11
If you do remove the soft top while the hardtop is fitted I strongly advise fitting suitable bolts and locknuts in the 3 threaded adjuster hole in each side so you can put the roof back in the same position and save yourself a lot of adjustment when you refit it. I speak from experience on this :oops: !
Back in Blighty
Nige
