Broken roof interior trim panel
Postby tj » Sun 15.02.2009, 19:50
During a moment of stupidity this morning when closing the roof on my S2 pushed against the grey trim panel just to outside of locking catches ?name which broke into two pieces. The plastic was very cold and looks brittle ?old age. It is part of a single panel running full length on the front of the roof and appears to be held in place by central grab "handle". It looks irrepairable. Is it possible to source a replacement part? Thanks
tj
Re: Broken roof interior trim panel
Postby Specky » Sun 15.02.2009, 20:00
Top tip....
If you go second hand... Source the parts from an SE/ or N/A... The reason being...The S2's are renound for there brittleness in the header area.
Postby tj » Wed 18.02.2009, 21:16
Thanks. Does anyone know source for second hand parts near East Anglia?
Also your message implies by word "if" that new parts might be available, would Lotus have a supply and if so anyone know what this bit is called ?part number?
Tim
tj
Postby Specky » Wed 18.02.2009, 21:25
As to sourcing a part... you could try martin
http://shop.ebay.co.uk/merchant/bnz897
Martin is in Spalding near Lincoln, he can be contacted in two ways
http://www.bargainpricedsheds.co.uk/ on this email sales@bargainpricedsheds.co.uk or by phone...etc
He is breaking two Elans, One Green, One red...
The green is nearly all gone and sold, but the red is nearly complete
Postby dedmans » Thu 19.02.2009, 14:01
I had fracturing of the plastic where the fixing nuts are. Rather than give up on it and trying to find new take the plastic section off( it is not difficult) and rebuild it with plastic padding underneath with a hessian /cloth backing support. Smoothoff the irregularities and then paint the whole panel with colour paint to match your trim. It is worth trying and with me gave a good result. If you get a replacement you will be throwing it away anyway.
All black S2
dedmans
