Removing light scratches from paintwork
Postby cider_fox » Tue 10.11.2026, 15:52
Hey all. My S2 has quite a few areas where there's very light scratches in the paintwork. Any tips on how to deal with it? I've no idea if it's special paint that needs to be treated differently to non-fibreglass cars. Or whether machine polishing is risky and hand polishing is better, or what type of polishing compounds are good. Any thoughts? Ta
cider_fox
Re: Removing light scratches from paintwork
Postby mcdonaa2804 » Wed 11.11.2026, 08:46
I've found with my S2, the paintwork has responded very well to machine polishing. It was very scratched on most panels, which I believe all to be original paint (Calypso red too...it was garaged for most of its life).
I used a DA machine with a 2 in one polish called Menzerna:
https://amzn.eu/d/0cM6djPf
I've also read that the original Lotus paint it pretty resilient and thick.
mcdonaa2804
Postby Tuga2112 » Wed 11.11.2026, 11:05
Trevor's your guy :lol:
Postby cider_fox » Sun 15.11.2026, 17:00
Thanks both! Much appreciated
cider_fox
Postby TrevorB » Mon 16.11.2026, 16:33
Tuga2112 wrote:Trevor's your guy :lol:
I also use Menzerna.
They do different grades depending on what you want to remove.
I also use a polisher for the work with different pads again depending on what you need to do.
Of course there are plenty of other products out there.
Trevor
:cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
