Replacing the entire back of the fiberglass body
Postby Falco » Fri 01.02.2008, 20:41
My car is severely damaged at the rear, so I have to cut of the entire back of the fiberglass body. I do have a non-damaged rear that i can use. The fibeglasswork is quite strait foreward, but cuting the glued parts free represent a problem to mee.
Please advise me in techniques and tools. (I have an other fiberglass body, where I can take the damaged pieces, but I have to remove the parts without damaging them. I intent to cut them apart where the are "glued" together)
Where can I get the "glue" needed for replacing an fixing the new parts ??
Any comments will be helpfull. :D
A lot of you in this forum must be experienced in fixing damaged fiberglass parts ;-)
Elan 90 white
Elan 91 Yellow
Falco
Postby chrisP » Mon 04.02.2008, 13:53
Hi there are references to replacing parts of the body work in the Elan Manuals, along with the cut lines, the required repair procedure and parts (glues) required. I'm sure someone can give you the exact chapter, as I don't have them to hand.
chrisP
Postby L.G. » Mon 04.02.2008, 17:43
Service manual section BJ is all about body repair. There is also a subtopic called "body removal" in BK. (body fittings)
L.G.
'95 S2 driver #286
L.G.
Postby Falco » Wed 06.02.2008, 20:45
L.G. wrote:Service manual section BJ is all about body repair. There is also a subtopic called "body removal" in BK. (body fittings)
L.G.
Thanks both,
I will stúdy it a little bit closer :)
But my challange is to dismantle the different body-part in the joining - the "gluei stuf" - it is difficult to cut in this material
Elan 90 white
Elan 91 Yellow
Falco
Postby surfboardfiller » Wed 06.02.2008, 21:15
I'm not sure which sections you are removing but:
Cut the glass with an angle grinder using a thin cutting disk (not a grinding disk). Mask, goggles, gloves etc (I just had to write that). This takes the weight off the join and gives you easy access. You can then cut closer or on the join.
Dried sikaflex should be fairly hard in places but you may wish to try heating it if it's already soft and puling the trim off or cutting the glue with a Stanley type knife.
If you are not experienced at this, then I would advise that it isn't the best job to learn on (if it's the structural part of the tub). I don't know how capable you are, so forgive me if I seem condescending, I don't mean to.
Some parts would be best repaired using a jig.
May be you could post a few pics up and let us see what you are up against. The 'service notes' manual is excellent, I'd advise buying one before you start your project as it goes into great detail.
Good luck!
Cheers,
surfboardfiller
Postby Falco » Fri 08.02.2008, 14:25
surferphil wrote:I'm not sure which sections you are removing but:
Good luck!
Cheers,
Now I have got the needed speacial tools for cutting the pieces apart
I have uploaded som pictures just to give an impresion of the repair :roll:
Falco
Postby lotusgirlmarie » Fri 08.02.2008, 18:57
:shock: :o Now thats a job!!!
lotusgirlmarie
Goddess
Postby Gary » Fri 08.02.2008, 19:19
I reckon you need a thread in the projects area to keep us upto date with progress !
Postby Specky » Fri 08.02.2008, 21:12
Are using the other shell for parts or using it to make a mould?
Postby surfboardfiller » Fri 08.02.2008, 22:40
Falco wrote:I have uploaded som pictures just to give an impresion of the repair :roll:
Where did you put the pics?
surfboardfiller
Postby Doug » Fri 08.02.2008, 22:49
there have been a few Elan owners in Denmark who have repaired or rebuilt Elans -- can't think of them off the top of my head, but maybe someone else can remember and get you their contact info . . .
Postby GeoffSmith » Fri 08.02.2008, 23:06
Doug wrote:there have been a few Elan owners in Denmark who have repaired or rebuilt Elans -- can't think of them off the top of my head, but maybe someone else can remember and get you their contact info . . .
He's already found Delta Doug!
Postby surfboardfiller » Sat 09.02.2008, 22:25
Wow! that's exactly the car I am looking for! (I kid you not!) I have a brand new tub in storage (it's even Left Hand Drive) and I'm looking for a yellow car with rear end damage! LOL!
Maybe have a look on the lotus site to see if they have another one in their sale, it could save you a lot of time.
:wink:
Top project though!
Jimbob's re build is worth a look if you haven't all ready.
surfboardfiller
Postby Falco » Wed 13.02.2008, 20:40
surferphil wrote:Wow! that's exactly the car I am looking for! (I kid you not!) I have a brand new tub in storage (it's even Left Hand Drive) and I'm looking for a yellow car with rear end damage! LOL!
:wink:
Top project though!
After some thinking and evaluation, i thing the easiest way to do it is simply to cut whole chassis in half (the manual describes how to replace the middel of the car), so the result will be a LHD front with a RHD rear. This way I even can reinforce the joint if necessary (under the car or under the carpet)
Elan 90 white
Elan 91 Yellow
Falco
Postby Paul.P » Wed 13.02.2008, 21:38
Falco wrote:After some thinking and evaluation, i thing the easiest way to do it is simply to cut whole chassis in half
Hope you mean body & not chassis ?
Postby surfboardfiller » Wed 13.02.2008, 22:28
Falco wrote:After some thinking and evaluation, i thing the easiest way to do it is simply to cut whole chassis in half (the manual describes how to replace the middel of the car), so the result will be a LHD front with a RHD rear. This way I even can reinforce the joint if necessary (under the car or under the carpet)
I thought that's what you would be doing (if you mean the bodyshell/tub); follow the seems. Make sure the fuel tank and all will match up before you do the switch. :wink:
surfboardfiller
Postby Falco » Thu 14.02.2008, 07:45
Oh yes, I mean the body and not the chassis :shock: :)
Elan 90 white
Elan 91 Yellow
Falco
Postby Falco » Thu 14.02.2008, 07:48
Yes thank you I will make shure that it fits. but it looks like the is no major differences between the LHD and RHD rear
Elan 90 white
Elan 91 Yellow
Falco
Postby F1 LOTUS » Thu 14.02.2008, 08:34
:twisted: :poke:
F1 LOTUS
Postby Dico » Fri 15.02.2008, 18:01
I'm 99% sure they are the same, apart from the front bulkhead (pedal assembly, etc), and the aerial hole.
