new front header rail seal
Postby router » Thu 28.06.2007, 19:35
I have purchased a new front header rail seal as mine has perished badly, im waiting for it to arrive does anyone have any experiences replacing it.
Is it easy to replace?
router
Postby ailwyn » Thu 28.06.2007, 20:19
I have no experience of fitting it, but I believe this is a fit-it-once part, so if your hood is not in a good way I'd suggest replacing it now, or you may find yourself needing a new header rail seal.
Postby router » Thu 28.06.2007, 20:49
The hood itself is in good nick its the seals that make it look rough.
router
Postby nickb » Fri 29.06.2007, 13:17
Out of interest how much did you pay if you dont mind me asking and from where?
It's one of those jobs I may do at some point.
nickb
Postby Monty » Fri 29.06.2007, 15:44
The header seal sits in a channel and i used sikaflex, but i heard someone using double sided tape (the foam type) so it would be easyer to remove in the future withouyt damaging it :?
Postby router » Fri 29.06.2007, 17:21
Great idea with the double sided tape might give that ago...
The seal isnt cheap and cost a staggering £120, but I feel it will be worth it in the end as mine at the moment is just a mess with foam hanging out.
router
Postby tango190 » Sat 07.07.2007, 11:00
Hi all,
Just curious on this hood seal problem.
As the hood seals wearing/leaking is a known issue with the Elan, hasn't Lotus ever put their hands up and done a recall or such like ??
Or
Do they offer a refurb service and how much ??
* Stands by to be shocked by cost *
MLOC Reject for Hire :)
tango190
header seal
Postby nickb » Mon 09.07.2007, 13:34
Did you purchase it from Lotus ? or another source??
nickb
Postby router » Mon 09.07.2007, 21:46
router
header seal
Postby nickb » Tue 10.07.2007, 12:34
Thanks.
nickb
