Proportioning Valve Fixing & Headlight Pod fixings
Postby paza1 » Thu 14.02.2008, 22:13
Anyone got the torque setting for:
1. the fixing to the chassis. Bolt is M6 X 12.
2. Headlight Pod fixings, 2 per pod, attached to mounting bracket, shimmed.
Mark
Silver 1992 SE Turbo.
paza1
Postby RayD » Fri 15.02.2008, 06:09
Hi Mark,
You don’t need any torque settings for these - just use an appropriate length spanner and tighten them in keeping with what you’d expect when taking them off.
