I also found that the heat build-up at standstill took a long time to 'normalize', with very little change occurring at speeds below 40 MPH - this is where LGM's solution should help matters. At higher speeds there's usually a higher-pressure bubble around the base of the windshield - hence my uncertainty if the vent works as expected then - simple tufts of wool should give an indication though
Doug wrote:well it was Brain MDB who did those
GeoffSmith wrote:It's a shame Phil didn't get the FatCat to Castle Combe. I was all ready with 16 channels of thermocouples to baseline the underbonnet temperatures under track conditions.
F1 LOTUS wrote:You could always baseline your car first
