roof fitters in the midlands area
Postby Jonathan Lawson » Tue 09.09.2008, 14:09
Hi there,
I am looking at buying a 1990 Elan SE Turbo and the roof is in need of replacing. I have been quoted £499 from Trim-Tech for S2 hood, 5 seals and an S1 adaptor kit, which sounds ideal. Where and who can anyone recomend to fit it all? Does the adaptor kit do a good enough job? Also the current roof is missing the straps is the frame likely to have become mis shaped? Any advice much appreciated. :?
Jonathan Lawson
Re: roof fitters in the midlands area
Postby Sy V » Tue 09.09.2008, 14:59
Welcome to LEC.
All fitters that I'm aware of (now Trim Tech no longer do it) are London-based.
Whereabouts in the Midlands are you based?
Postby ailwyn » Tue 09.09.2008, 15:29
Sy, Don't forget that there are 2 trim techs in the midlands, not sure which is which, but the one that no longer does them (the OEM) is in Coventry.
Postby Jonathan Lawson » Tue 09.09.2008, 16:46
Thanks for welcome,
Yes it was trim-tech in coventry that quoted £499 roof, seals + kit, have found The Hood Guys in Birmingham who would fit for £376 inc VAT, I am in Stratford-Upon-Avon, they seemed confident about doing the job although they don't get many Elans, and suggested that I may have to take it back to them for adjustments to get it as watertight as possible which they would not charge me for ! ! !
From reading through the forum history most people opt for the trim-tech pack, Would I end up with a signifcantly better result paying more money for all the original S1 seals (£500) and roof and straps made for possibly upwards of £750, so could end up paying £1200 > £1500 as oppose to the trim-tech route of £900.
Has anyone got the contact details for the other trim-tech in the Midlands? :roll:
Jonathan Lawson
Postby Jackonicko » Tue 09.09.2008, 17:01
I was quoted £250 fitting by PAUL NAHOULAKIAN at Drayton, Nr Abingdon, on 01235 528893 – he’d need the car for a day.
You could also get the hood fitted by Austins Trim at 7 Queensford Farm, Dorchester-on-Thames, Wallingford, Oxfordshire OX10 7PH
Tel: 01865 341988. I'm sure they'd do a 'Rolls Royce' job.
Jackonicko
Postby Sy V » Wed 10.09.2008, 08:39
ailwyn wrote:Sy, Don't forget that there are 2 trim techs in the midlands, not sure which is which, but the one that no longer does them (the OEM) is in Coventry.
I can't forget something that I never knew, mate.
Coventry Trim-Tech (previously Tickford) are the only ones that I know of...
Postby ailwyn » Wed 10.09.2008, 08:50
Postby Jonathan Lawson » Wed 10.09.2008, 11:28
Have found a Trim-Tec in Dudley Port, West Midlands, DY4 7PR: 01215 579977, spoke to Joe, will fit the trim-tech S2 roof kit for £150 inc VAT and garantee his work. :o :)
Jonathan Lawson
