Petrol flap release puller
Postby al » Sun 31.05.2009, 21:15
Hey guys,
anyone know how to get to the nut that holds the petrol flap release puller in the passenger door recess ?
Stopped to put some fuel in today and the whole lot came away in my hand :oops:
a.
al
LEC Bit Basher
Re: Petrol flap release puller
Postby lotusgirlmarie » Sun 31.05.2009, 21:28
Open the soft top storage area. Remove the carpet. Remove the screws that holt the plastic tray on the fuel filler side. Remove the tray. Lossen the band that holds the fuel filler neck to the inlet. Remove the rubber filler neck. Reach down inside and tighten the nut that holds the flap release and reinstall in reverse order. It's a pain but easily doable. You will not be able to see the nut, only feel it.
lotusgirlmarie
Goddess
Postby al » Sun 31.05.2009, 21:44
Sweet, thanks !
:banana:
al
LEC Bit Basher
Postby Tannerman » Fri 05.06.2009, 13:10
Does anyone know where i can get the plastic shrowd from as mine is nik knacked.
Lotus Elan M100 1990 (red
VW Tiguan R Line
Ford Transit Jumbo
Toyota Celica 25 th anniversary model
Tannerman
