by mikesimmo » Thu 06.01.2011, 21:08
Could someone please double check I have found the correct part numbers for a:-
Sept. 1992, Lotus Elan, SE, Vin no’s. N6751, replacement roof seals.
Looking on Page 11.01a of the Parts guide.
Glazing, Weather-strips & Seals
Part numbers from the exploded diagrams
12 Seal A Pillar LH B100V0117F
Seal A Pillar RH B100V0118F
80 Seal Cant. Rail LH A100V0123F
81 Seal Cant. Rail RH A100V0124F
76 Seal Falling Pillar LH C100V0121F
Seal Falling Pillar RH C100V0122F
Are these correct ?
Elan novice
mikesimmo
mikesimmo
by theelanman » Thu 06.01.2011, 21:15
without checking.......
I thought they would all fit either hood except the header rail seal.....as the header rail on the S2 hood is longer....
if I get chance I'll check....unless someone else jumps in
