nitroman wrote:Eagle One NanoWax Shine
I picked this up the other day only because I was going to detail my car.
Easy use products tend to not work for me.
1. It does supply a glass like shine on the parts I tended to and was very easy to use.
One area of interest is that it does not discolor the trim.
2. On the areas that had previous clear coat scratches like when you take your finger and wipe
away a bug it does gloss over the scratch. The scratch however is still their. I then took some
paste wax and applied it to the scratch just treated using standard procedure. The scratch
tended to disappear better with the past wax. I figure this was due to the fact that I polished out
the clear coat.
3. In daylight the product is fine but under florescent lighting you see all the flaws in the surface which
is why I tried the paste wax.
4. I am no polishing expert but would call this product a very good detailer when you want to clear the surface
of pollen, bugs and general road dirt but only after you have applied a good base of paste wax.
Steve -w- a shining example of an M-100
