Roof and liner on hood
Postby dickendoe » Fri 04.05.2012, 07:31
Hi,
my recently delivered car has a good hood, suspect it is pretty new. But there is no handle for lifting it, though there are flanges to screw something to, and there is no liner.
Was there a liner? And any thoughts on where to get hold of a replacement for the bit that is missing (presumably a panel with a handle built in)?
Lotus, giving new meaning to 'better to travel hopefully than arrive'
White Elan S2
dickendoe
Re: Roof and liner on hood
Postby rip » Fri 04.05.2012, 09:28
I am not sure the roof would fit into its stowage space if it had a liner so no, it never had one.
Postby dickendoe » Fri 04.05.2012, 09:34
Thanks - should there be a handle for pulling the hood assembly out?
White Elan S2
dickendoe
Postby RayD » Fri 04.05.2012, 10:12
Postby dickendoe » Fri 04.05.2012, 12:38
Thanks Ray, that is a big bit of trim to be missing!
White Elan S2
dickendoe
Postby racerstev » Fri 04.05.2012, 13:53
I think the reason it's missing is breakage, they seem to break at the 3 screw holes and along
the edge of the latchs.
Steve
racerstev
Postby nyssa7 » Fri 04.05.2012, 16:01
Anyone got a picture of the whole roof from the inside? Mine has all sorts of straps dangling down, not sure where they should be
nyssa7
Postby RayD » Fri 04.05.2012, 19:53
Have a look here and here or search though my posts using the word "elastic"
Let me know if anything's not clear.
Postby dickendoe » Fri 04.05.2012, 22:20
Great stuff, thanks Ray, will use to get to know my hood a bit better. Will also start my quest for that missing trim panel!
White Elan S2
dickendoe
