by novacaine » Sat 31.05.2014, 19:57
Hi all I need help again!
My hood appears to be breaking my intermediate seals (both sides). When the hood is folded the outside face of the seal is resting on the metal frame and pushing up, which has caused the brand new seal I bought are buggered.
I have another set of SE type intermediates that I don't want to use if my hood is just going to break them again. Looking at the two different seals the S2 (newer design) seem to be a lot softer and have a more brittle outer coating, whereas the older SE seals feel tougher and compress without causing too much obvious stress to the outer coating.
Is this common and is there any way to stop it from happening again?
At the moment I've quickly patched them up with black duct tape while I'm waiting for my delivery of sikaflex
novacaine
by novacaine » Tue 03.06.2014, 07:01
any ideas?
novacaine
by Jamie N » Wed 04.06.2014, 10:44
Jonathan, is that picture not the side part of the header seal?, im struggling to work it out with that picture, maybe the seal is just too soft and brittle like you say, is the seal breaking away from the bracket or is part of the hood doing the damage?.
Jamie N
- Seal God
by novacaine » Wed 04.06.2014, 21:01
Its the rear edge of the intermediate. It's really frustrating, and I guessI it isn't common. I might just chance using the older SE intermediates that I have, until you have a set of the nice folding lip seals
novacaine
by stevebow » Wed 04.06.2014, 22:45
That happens on mine to and I put it down to the intermediate seal having too many spacers behind it, so that it meets the door glass. So I adjusted my door glass as much as possible to meet the seal without spacers, although I still need spacers.
stevebow
by novacaine » Thu 05.06.2014, 06:01
I thought spacers could be the cause but I have one spacer either side, which is standard :S
novacaine
by Steve A » Sun 28.09.2014, 23:26
by Jamie N » Mon 29.09.2014, 11:51
Or an affordable Hardtop
Jamie N
- Seal God
by novacaine » Tue 30.09.2014, 19:47
The hardtop is in the making! lol
This problem is nowhere need as bad with the rubber seals. Such a poor design by lotus though
novacaine
