Bonnet Stops
Bonnet Stops
Postby epipete » Fri 14.11.2014, 23:25
Whilst not the most vital requirement on my list, since I'm currently refurbing my Light Motors and replacing the Lenses and generally tidying the area up, I note that the rubber caps on my (rusty) bonnet stops are perished.
It's probably the easiest job in Elan ownership to replace these bits or would be if I could find some! Does anyone know what I am looking for, ebay hasn't proved much use?
I assume the bolt is just a length of M6 with a couple of nuts and washers.
Pete
Re: Bonnet Stops
Postby GeoffSmith » Fri 14.11.2014, 23:39
Just did mine (dead easy job) and what a difference. Couldn't find anything sensible, so went to SJ's and got X046B6113Z @ 85p.
Re: Bonnet Stops
Postby dapinky » Fri 14.11.2014, 23:44
Pete,
The bolts are a standard hex-head M8 bolt (with a 13mm head).....
.... I have just (well, recently anyway) replaced all mine with stainless items. (but have used some stainless socket-head bolts)
The rubber caps are available from SJ's for 85p each (part no X046B6113Z).
I bought 8 of them - 6 for the bonet, 2 for the boot.
The biggest issue is paying Steve's P&P for a small order (but he's a business, so can't complain!) - as I had ammassed a larger order, it wasn't a problem.
That said, any 13mm rubber ferrule will probably do the job just as well, and there were a few on ebay when I was looking... something like this - the sort of thing for a walking stick or chair leg - maybe even something in B&Q or similar??
Re: Bonnet Stops
Postby epipete » Fri 14.11.2014, 23:53
Thanks Guys,
The wretched thing is so rusted I may have to cut it off and go the Stainless route (probably best anyway).
Re: Bonnet Stops
Postby Jamie N » Sat 15.11.2014, 10:34
Multitude of different versions of them in breakers yards as well :wink:
Monaco S2 #406
Jamie N
Seal God
