epipete wrote:I'm not sure off hand but I'd open the Hood Storage deck, remove the trim which should allow sight of the cables running to the mechanism a tug of which should open the flap. As to the door, I'm still considering that one
Bug4029 wrote:Phil your a star. It worked and I'm mobile, just the door to figure out tomorrow now.
lotusflasherman wrote:
Good news... just get two credit cards (for stiffness) and push them into the slot of the filler flap towards the rear and the flap will spring open - just done it on mine:
dapinky wrote:The easiest way to open the filler flap is to gently slip a credit card (or any other slim, rigid plastic card!) between the rear edge of the flap and the bodyshell.
If you look into the gap, you will see the plastic bit which catches the flap shut - it is tapered, and gentle inwards pressure on it will cause it to move and release the flap.
As for the door - a whole different ball game!
epipete wrote:dapinky wrote:The easiest way to open the filler flap is to gently slip a credit card (or any other slim, rigid plastic card!) between the rear edge of the flap and the bodyshell.
Dave, did you read this thread?
lotusflasherman wrote: ... just get two credit cards (for stiffness) and push them into the slot of the filler flap towards the rear and the flap will spring open - just done it on mine....
Elanlover wrote:lotusflasherman wrote: ... just get two credit cards (for stiffness) and push them into the slot of the filler flap towards the rear and the flap will spring open - just done it on mine....dapinky wrote:The easiest way to open the filler flap is to gently slip a credit card (or any other slim, rigid plastic card!) between the rear edge of the flap and the bodyshell.
Evidence of a misspent youth.
I confess Enright wrote:…pressing a lift button repeatedly in the hope that it will speed it up!
GeoffSmith wrote:Enright wrote:…pressing a lift button repeatedly in the hope that it will speed it up!
It's the ONLY way to get our lifts at work to go.
dapinky wrote:
... and if you keep that attitude up, I'll take my bat and ball and go home
