by JMP » Thu 27.08.2015, 21:45
Should you want to change you windcreen wipers or simply clean the windscreen without them get in the way, here is the way to do so :
Did you ever notice the two tiny holes that are close to the hinge?
They are there to enable a metal rod to block the system in the raised position, once you have pulled the arm.
But let's see it, pictures speak more than words...
Without the metal rod :
With :
Lotus Seven s3
Lotus Elan M100 SE
Lotus Elise S1 PTP 165
JMP
by tb10 » Thu 27.08.2015, 22:08
ahhhhh
Très Bien
tb10
by Tuga2112 » Thu 27.08.2015, 22:31
useful information thanks.
sadly my issue with the wipers is not keeping them up, is the fact they barely leave the glass not leaving much room for moving a hand around (or putting in some masking tape)
by JMP » Thu 27.08.2015, 22:52
Sorry but I do not understand your issue. Why are you referring to masking tape? For some paint job on the bonnet?
Having the windscreen raised is useful for removing them by the way. I found this tip when I wanted to remove an arm and replace it by a NOS one.
Lotus Seven s3
Lotus Elan M100 SE
JMP
by Jamie N » Fri 28.08.2015, 11:48
Or you can replace both of them completly with some modern ones from a Vauxhall (exact same fitting) , stronger spring for better clearing and can be raised right up for cleaning the glass. Couple of £ from any Scrapyard.
Jamie N
- Seal God
by Tuga2112 » Sun 30.08.2015, 20:04
JMP wrote:Sorry but I do not understand your issue. Why are you referring to masking tape? For some paint job on the bonnet?
more of a paint job on the whole car
the fact they barely move up just makes it a pain to wash the windcreen as well. but nothing worth a couple of £ on a scrapyard
