Stopping the soft top ballooning at speed and liner
Postby chrisP » Wed 11.10.2017, 10:34
Hi all, I am sure you have all experienced having the soft-top up and driving at speed - with the pressure differential the soft-top balloons away from the frame. Modern convertibles don't have this problem, as I guess there are extra connection points between the the fabric and the frame. My question has anyone looked into fixing this problem??
Secondly has anyone looked at or created an insulated liner
chrisP
Re: Stopping the soft top ballooning at speed and liner
Postby Rambo » Wed 11.10.2017, 10:44
Easy solution. Open both windows a crack to equalise pressure. Result, no ballooning :wink:
Postby Bern » Wed 11.10.2017, 11:03
Easily fixed, only drive with the roof down!
'90 Elan SE
'95 MGF
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
'80ish Kubota B5100E
Bern
Postby simonbuk » Wed 11.10.2017, 11:06
Does it matter though ?
And I guess any insulation added as an after thought might just attract/trap moisture ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby chrisP » Wed 11.10.2017, 13:37
Thanks for the help guys, :roll:
It does matter to an extent, once I get to a certain speed the soft top pulls the rear seal off the rear deck (yes the frame is tension-ed correctly).
With the liner I was wanting to make the car more live-able in inclement weather.
chrisP
Postby Dave Eds » Wed 11.10.2017, 14:42
Beanie hat?
Bobble hat?
Ill get my coat..............
Postby Giniw » Wed 11.10.2017, 14:57
chrisP wrote:once I get to a certain speed the soft top pulls the rear seal off the rear deck
That sounds strange to me, I never noticed that. It's ballooning a bit, but the rear seal doesn't move.
And my hood is not really well adjusted and the webbings are shot — it's another thing in my todo list.
Giniw
Postby dapinky » Wed 11.10.2017, 15:20
Chris,
There are a couple of vents between the boot and the interior to allow air pressure to equalise - they don't work if the boot is too full, and they are marginal at best.
Does it only happen with the dash vents open, or all the time?
Postby chrisP » Wed 11.10.2017, 15:52
Hi Dave, yes the vents appear to be functional - well they are there and move, the boot is empty - but I have an idea that the vents actually suck exhaust gasses into the boot and passenger compartment (perhaps that is part of the issue perhaps not) But I have seen other Elan soft-tops ballooning. You just don't see it on modern convertibles
chrisP
Postby Paul Alexander » Wed 11.10.2017, 16:20
chrisP wrote:Thanks for the help guys, :roll:
Hi Chris, i used to get this problem. have you go the offset cams adjusted correctly on the sides of the hood frame, towards the rear? the cam should stop the hood lifting at speed (75 mph or above when it happened on mine).
Paul Alexander
Postby Rambo » Wed 11.10.2017, 16:58
chrisP wrote:Hi Dave, yes the vents appear to be functional - well they are there and move, the boot is empty - but I have an idea that the vents actually suck exhaust gasses into the boot and passenger compartment (perhaps that is part of the issue perhaps not) But I have seen other Elan soft-tops ballooning. You just don't see it on modern convertibles
That's a problem you definitely dont want :shock: Sucking CO, CO2 and other exhaust gases into the inside cabin is a recipe for disaster. :shock: :shock:
Postby rip » Wed 11.10.2017, 17:09
Rambo wrote:Easy solution. Open both windows a crack to equalise pressure. Result, no ballooning :wink:
Without going out specifically to test for this, it will have little effect.
It is because fast moving air creates a low pressure & was discovered by Daniel Bernoulli.
It is why aircraft can fly & why it is possible to sail partially into the wind.
Postby Rambo » Wed 11.10.2017, 17:38
It seems to work for me in the yellow one rip. Its probably down to Rambo's Theorem rather than Bernoulli's Principle :lol:
Postby Bern » Wed 11.10.2017, 21:36
I'm sure I'm totally wrong here, but isn't that sort of why opening a window works? You get lower pressure inside the car so the air inside is drawn out (and the ballooning stops)?
I did once drive at motorway speeds with the hood up (it was raining really heavily and I had a passenger who wasn't a fresh air enthusiast, tsk), I don't remember there being any ballooning of the hood.
'90 Elan SE
'95 MGF
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
Bern
Postby Simon_P » Wed 11.10.2017, 22:01
The tension sets the frame go over-centre on the pivot, which locks the panel in place on the rear deck.
You can only unlock it by folding the hood, so if it is lifting something is wrong with the hood frame adjustment.
