by nitroman » Wed 07.12.2005, 00:35
At last, Scott Levine who works at Team Ford is going to hook me up with the guy who makes their custom under-bonnet insulation for their special shop cars. The guy will make a template of the "large" piece from my car (the small piece at the front is readily available). Using that template he will cut a new piece of insulation and then cover it in felt (any color). He also has the ability to air-brush any logo you want on it. He showed me a couple at the shop & they look really eye-catching!
Will let you know more as things progress. Should I tell him to keep the template in case anyone else wants one? It will not come with a peel-off 3M backing as the OE piece has. Rather you would use spray adhesive then press it against the bonnet.
nitroman
by Doug » Wed 07.12.2005, 02:04
Sounds like fun and I am intrigued!
Won't a painted surface be awful close to the hot engine head? The bonnet prop rod may brush against it too and damage it?
I have seen "impressions/imprints/stampings" of logos in BMWs and they looked nice. Thus I would suggest an imprint of the Lotus logo or the Cat on Skates would be a very cool thing . . .
- LEC Founder
by F1 LOTUS » Wed 07.12.2005, 02:30
Hmm...a black cat logo on vacuum deposited gold mylar N-I-C-E
F1 LOTUS
by Ashaman » Thu 08.12.2005, 03:27
Any idea of the cost? I was planning on buying Thermo-tec's product, but this would probably look a bit cooler!
Ashaman
by nitroman » Thu 08.12.2005, 05:28
Will let you know once I've talked to the guy. I'm picking up my Lincoln this Saturday as he could not pinpoint the air-ride suspension problem (leaking or failing to inflate) so I just converted it to normal springs while leaving the computer-controlled shocks (the computer changes the internal valving real-time, a la "active-suspension"). Anyway, once he locates the guy he'll have my number regardless of where I am.
nitroman
by nitroman » Fri 09.12.2005, 01:18
I looked today & the bonnet prop rod never comes in contact with the insulation; in fact it is surprisingly far away from it... about 2". The only areas I know that come in contact with the insulation are near the top of the strut towers.
As for heat affecting his work I can only assume he has been doing this long enough to know what materials will survive in the hot environment. He can integrate a separate "hard" logo if you do not want airbrushing done. If you have one you want to use you'd need to supply it in advance.
nitroman
by Matt RI » Thu 15.12.2005, 06:50
Ah- back to work prettying your clean machine... You must be feeling better, Matt!
I am interested in learning how this works for you. Mine is pretty tattered, and I would not mind replacing it. I guess that is the downside of a low mileage Elan- means it was sitting in someone's garage making a nice home for a mouse family at some point...
Did you have problems removing the old one completely so as to avoid problems with getting the new one to adhere correctly?
I like traffic lights. But only when they're green...
Matt RI
by nitroman » Thu 05.01.2006, 01:14
If you go to
http://jaggraveyard.com/ & give them the dimensions of the underhood pad you need they can provide you a piece of the silver heat-resistant variety.
nitroman
by Pascal » Tue 30.04.2013, 22:33
Hello ,
i open this old topic again ...
as many others, my insulation under bonnet is dead burnt, and excess of heat to the fiberglass is causing some surface gelcoat defects.
i plan to replace the insulation foam - i have found some 10 mm thick, self adhesive, with a layer of aluminium on visible side.
I wonder ...
1° has someeone done such a replacement and faced some tricks ?
2° could the alu foil reflect an excess of ray to the engine and cause a heat problem, as the bonnet is very near the engine ?
have a great day,
Pascal
2020 May 21- Ieper Lotus Day ! I'm not ready ! I need a hair cut ! Pascal - North of France - 1991 SE Turbo Calypso (faded to pink) Red and an additional Elise somewhere in the garage
Pascal
Users browsing this forum: AhrefsBot and 3 guests
