Where to find vin plate
Postby CARSCARS » Sun 16.04.2006, 22:58
Hi everyone
where abouts is the vin plate and engine number on an se
thanks :?
CARSCARS
Re: Where to find vin plate
Postby muley » Sun 16.04.2006, 23:02
CARSCARS wrote:Hi everyone
thanks :?
Not sure about 'vin plate' The chassis number / car number is stamped on the end of the RH (driver's side) rear suspension mount - normally you can see this without taking the wheel off - yes, it's there under all that gunk.
Hope this helps
Jim B a.k.a. muley
Postby CARSCARS » Sun 16.04.2006, 23:05
thanks thats great
CARSCARS
Postby Darren » Sun 16.04.2006, 23:15
Engine number is on the front of the engine. Kinda where the gearbox & engine join. It's lower than the turbo on the right hand side and almost obscured by one of the ridgid 'lines' that connect to the turbo. The number itself is stamped vertically, on a 'thin' piece of the casting i.e it's no more than 5 to 10mm wide.
Owwww and it will be covered in crud, but with a good 'clean' it's actually quite easy to read. Owwww if you have a N/A it's even easier i.e no turbo to get in the way.
Darren.
Open mouth, insert foot.
Darren
Postby CARSCARS » Sun 16.04.2006, 23:21
thankyou for that
CARSCARS
Postby Doug » Mon 17.04.2006, 00:02
if you want to get real tricky, I noticed the doors also have a VIN plate stuck to the bottom of them--straight in the bottom by the weatherstripping where all the gunk collects 8)
