Interior Air Duct between body & heater/AC
Postby donsladek » Mon 01.01.2007, 01:48
Folks,
I'm trying to determine the part number for the flexible duct between the body and the heater/air conditioner box. Located at upper rear of right side front wheelwell, after removal of fender liner. Mine is a foam part, may not be OEM , see attached picture.
I tried locating it on the parts guide, but no luck.
Anyone know the part number?
Thanks!
Don Sladek
Don Sladek
Calypso Red '91 #37594
donsladek
foam
Postby stonefish » Tue 30.01.2007, 18:24
the part number for the foam insert is A100P0096F, i replaced mine because water saturated the foam and leaked into the heater blower, thus misting up the windscreen..it now does not mist up..
stonefish
Postby DeeAitch » Tue 30.01.2007, 23:31
Mine dissintegrated, got sucked into the fan and smelt aweful :evil: Replaced it from a section cut from an inner tube - fitted perfect!
DeeAitch
