by Andy_Bailey » Wed 04.04.2007, 20:09
As it is a lovely night tonight i drove back from work top down only to get home and pull the roof cable and nothing, i'm guessing the cable is buggered. I now have a car that's not secure and is also parked on the road
(hope it doesn't rain!)
Is there any way of releasing the catches so i can at least put the hood up?
Thanks in advance!
Andy
The Durango '95 purred away a real horrorshow. A nice warm vibraty feeling all through your guttiwuts!
Andy_Bailey
by John_W » Wed 04.04.2007, 20:35
You should be able to operate the catches on top of the two vertical pillars manually somehow. I can't have a look just now, but you should be able to manage something with a screwdriver and pliers. If you need access, the plastic covers come off the pillars.
Not much help I know, but it should be possible.
Good luck.
- Heid-bummer
by Andy_Bailey » Thu 05.04.2007, 01:06
Thanks for the reply John - looks like a job for the weekend
Andy_Bailey
by Andy_Bailey » Sat 07.04.2007, 18:35
OK - i've had a further dig around and the problem is not with the cable. The actual problem is the LHS link rod has broke off from the bellcrank lever so the catch is not operated when the cable is pulled. I can't quite suss out if it's fixable or whether i'll need to replace the mechanism yet
Anybody else had a similar problem before? Thanks in advance!
Andy
Andy_Bailey
