What is it,what does it do?
Postby paza1 » Sat 07.04.2007, 22:03
Fiddling about in the (UK) n/s wheel arch, with liner off (what a job!!), saw the attached component (in the middle of the picture, the one with a rubber bellows affair). I suspect it is a shock absorber, possibly. It rattles about when moved but is secured at both ends with washers and a nyloc nut (bottom end in view).
My questions are what is it and should it be "loose". I am not mechanically savvy so any info/help much appreciated.
Mark
Silver 1992 SE Turbo.
paza1
Postby Dico » Sat 07.04.2007, 22:31
Its a shock absorber thingy thats stops the gearbox from being shaken to bits. Don't think it should rattle though :shock:
Postby paza1 » Sat 07.04.2007, 22:57
Thanks for the info Dico. It looks like the nut can be tightened to take up the slack...should I?
Mark
paza1
Postby Sy V » Sun 08.04.2007, 04:04
Yes, tighten it up at both ends (top and bottom) 10mm if I remember correctly.
Postby Specky » Sun 08.04.2007, 11:13
IMHO If it's come loose..... chances are it will again....
FWIW Throw on some new Nylocs... or for the short term obtain some thread lock...
Postby paza1 » Sun 08.04.2007, 12:50
Thanks everyone, will do as suggested
Mark
paza1
Postby Enright » Sun 08.04.2007, 19:14
Here's another suggestion then (WRT your "what a job" comment):
Contact Dave and get a set of these off him.
WELL worth it for next time.
Postby paza1 » Sun 08.04.2007, 20:30
Totally agree. Got the stuff from him last year and excellent quality it is. Should be a breeze next time the liners have to come off. Rear o/s done (easy, just be aware of the washer bottle is secured with two of the bolts going through for the liner fixing.). Front n/s in progress. Had to cut 2 bolts off with an angle grinder. De-rust, Kurust and Hammerite in progress.
Possibly off topic but I am having a good look around the area behind the liner partly because I will need to replace the soild brake line going from the flexible lines to a union at some point. Anyone got any hints/tips for a novice?
Mark
paza1
Postby Candles » Sun 08.04.2007, 21:51
Yes, get either a proper brake pipe spanner or a set of crow's-feet spanners. The union nuts will be so tightly corroded in that you'll blind the nuts trying to undo them otherwise. Start wire-brushing and applying WD-40 now as well!
Candles.
Candles
Postby paza1 » Mon 09.04.2007, 18:02
Will do Candles. Thanks for the info.
Shake Damper, secondary, item 80, page 2, Engine section 40.01B. Mine rattles top and bottom fixings. Tried tightening the bottom and the bolt snapped off. Replaced with new M6 bolt and nyloc nut but doesn't seem to want to tighten enough to stop the assembly rattling.
Questions....what torque?
could the spigot be worn so the spacing is is wrong :smt102
Sy, correct, 10mm nut and bolt M6. :bowdown:
Any help/info for a numpty appreciated
Mark
paza1
Postby paza1 » Mon 09.04.2007, 22:32
I am not sure that the nut will tighten any further because it presses against the spigot (which seems to act as a spacer). Can someone have a quick check on theirs sometime please? You can access it from above.
Mark
paza1
Postby Sy V » Tue 10.04.2007, 05:33
There is a spacer, but IIRC the Federal ones and later UK ones are different set-ups, slightly.
Postby paza1 » Tue 10.04.2007, 13:53
Judging by the condition of the nuts and bolts, I would say that they are the original set up so will be UK fit
Mark
paza1
Postby paza1 » Wed 11.04.2007, 22:08
Anyone tinkering who could have a quick look?
Mark
paza1
