by kbee » Mon 24.05.2021, 15:55
Hi I have a high tickover rate 1200 ish and a fault code 23 ( low manifold temp ) , could someone be kind enough to tell me where the sensor is . Would it be worthwhile to change coolant sensor at the same time . cheers
kbee
by Simon_P » Mon 24.05.2021, 16:06
The MAT sensor is on the back of the plenum a few inches inboard from the throttle body.
by GeoffSmith » Mon 24.05.2021, 18:33
Check the wiring/connector. It could just be a bad contact rather than the MAT.
- Kitty Fiddler
by kbee » Tue 25.05.2021, 09:53
thanks found it connections are fine the sensor is badly rusted so will replace anyway , one less thing to go wrong.
kbee
Users browsing this forum: No registered users and 16 guests
