Home | WikiLEC | Repairs | Upgrades | Gallery | Buy & Sell | Mountain Chips | Meets & Events | Contact |
Tuga2112 wrote:just to clarify.
as of right now. if you turn the key to the "on" position. but dont start the car.
does the boost gauge read zero or is it reading the same as in the picture ?
the wastegate wiggle (see the wiki) is something that is free to do, and has a chance to solve your issue of not getting any boost. (assuming the wastegate is stuck open)
what i'm most curious about what you describe is the gauge reading. which could be due to multiple different issues,
HJ2 wrote:It should be horizontal or zero.
I would start by checking the ground connection at the sender
Undo, clean the contacts and secure the screw & plug again.
If that does not help: check the ground wire with a multimeter or temporarely connect it to a ground elsewhere on the block for troubleshooting
Good luck!
RonR wrote:I see you have a Dump Valve fitted, it might be worth checking it out. If the diaphragm gets stuck open it could affect the boost.
Tuga2112 wrote:id suggest to remove both wires at the transducer end. and clean their connections throuly and refit.
then turn the key again and check if the boost gauge is on the zero or if it moved up again.
if that is still moving up.
disconnect the wires. and with the key on, check the voltage across them with a multimeter.
i wonder if there is something else tapped into that circuit that shouldnt be there.
also check what is the gauge reading when both wires are disconnected. (again should be zero)
GreasyJoe wrote:Update - in between the snow, rain and wind was out on the car today being nice weather.
Not sure why I started with the wastegate, wish I hadn't really. Hassel of taking off the third bolt holding the wastegate plate to the turbo housing was a pain. Finally got it off, but to try and get at the circlip at the other end I had to take off the heat shield. Had avoided it due to the bolts being so tight and two out of three virtually inaccessible. Got it off eventually. nearly took most of the day doing it. Then noticed the other lower heat shield still covering where the circlip is. Just one bolt too many. Thing wont budge.
So having the wastegate loose, with it only attached at the circlip end, its hose off, I wiggled it as much as I could in all directions hoping that will be enough to free it up if it was ever stuck in the first place. It seemed pretty movable.
Finally went to put the heat shield back on but had to give up for the day. The two side bolts are a nightmare. Virtually only can be done by feel and fingers. And can I line it up with the holes! Have the car jacked up for the left one as its the only way to undo it let alone get the thing back in place. Hopefully I may be lucky tomorrow and they all align first time. Any tips on getting these things in place welcome!
One good thing though. Found why the boost gauge is sitting off the zero mark. Wire on the transducer screw though tight was earthing badly. After getting it all off found both wire and plate was rusty. I think there must have been some current getting through but hardly. Was stopping the boost gauge going up to max. Managed to get the transducer off. The rubber nuts were in a mess and was a struggle getting them off too. Will need replacing. Sanded down the rusty surface and clamped the wire to the transducer body. Boost gauge back to normal.
Once I get it all back together I'll finally be able to see if the turbo is behaving or not. I hope it is.
All I got to say is the guys who designed this car must have been sadists lol
I love the car but the work I need to do on it may be too much for me. I don't have the facilities and didn't realise how much was involved in working on this car. Watch this space as I may be selling it soon
FunElan wrote:Do you hear the whistle at all? You should be able to feel boost if you floor it in 2nd gear. It should be obvious, at least it is in my car. .
Maybe you need to check for boost leaks. You could use a bike pump and pressurize the system as mentioned on here. Or maybe a smoke test. Haven't read the whole thread, but do you have access to elanscan? It'll tell you if it's boosting
TorqueHorse wrote:Heat shield bolt would have no impact to your boost. But I agree with FunElan on double checking that all your hoses along the entire run are snug up. Especially if you were knocking around the turbo before for the wastegate and heat shield, you may have knocked something else loose unintentionally. If you want to understand how the boost system works on the Elan (In what I think is more easy to understand language than the workshop manuals) you can learn more from https://elanchips.co.uk/ (even if the mountain chips aren't available anymore, the content there is great)
dapinky wrote:The easiest way to establish if you have a vacuum pipe off is to run the car at idle, then deliberately remove an easily-accessible hose. You should hear the engine speed drop before picking up again and settling very slightly higher than you started as the sensors try to make up for the sudden changes in pressure in the manifold.
If you don't get any change at all, then it in an indication that there is already a 'leak' so the sensors don't have to do anything.... all you then have to do is find the leak & fix it!
GreasyJoe wrote:Hi Dave. Thanks for the advice. Sounds the best way to start investigation. Sorry to sound a bit thick but can you recommend a particular hose?
dapinky wrote:GreasyJoe wrote:Hi Dave. Thanks for the advice. Sounds the best way to start investigation. Sorry to sound a bit thick but can you recommend a particular hose?
It really doesn't matter - but probably the easiest one is the pipe between the turbo sender unit on the drivers inner wing and the inlet manifold - at least you can see and feel the whole thing!
