3D Printable Wire Bending Jig for fuel injector clips
Postby SomeoneTakeTheWheel » Mon 12.10.2026, 19:20
In replacing my fuel injectors, I didn't like the condition of some of the little wire clips that lock the electrical connector on. I decided to make my own, but they are a very specific shape. So I designed a jig that would let you bend and trim 0.9mm spring steel wire into the exact shape needed.
I recommend printing in PETG or ABS or stronger. I printed in PLA and the strength of the steel wore that jig out after 2 uses.
https://www.thingiverse.com/thing:7421531
SomeoneTakeTheWheel
Re: 3D Printable Wire Bending Jig for fuel injector clips
Postby DublinBlueElan » Tue 13.10.2026, 16:39
Interesting, do you have any other 3D prints relating to our cars?
1992 Aqua Blue se turbo
DublinBlueElan
