Turbo drain pipe blocked?
Re: Where did this come off???
Postby Grampy » Wed 14.09.2016, 22:39
Thanks very much
Lotus Elan SE
lotus Elise S1
Golf R32
Audi A4 mile cruncher
Grampy
Re: Big day tomorrow
Postby Grampy » Thu 15.09.2016, 09:12
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Where did this come from part 2
Postby Grampy » Thu 15.09.2016, 20:08
Thanks in advance
Craig :bowdown:
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Re: Where did this come from part 2
Postby lotusflasherman » Thu 15.09.2016, 20:44
Looks like the turbo support bracket that fixes outlet end of turbo to block ..
Postby lotusflasherman » Thu 15.09.2016, 20:55
Item 38 ?
They call it wastegate support bracket..
Postby Grampy » Thu 15.09.2016, 21:06
Not so sure Phil looks a bit big
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Postby tigerdog » Thu 15.09.2016, 21:15
:smt023
Postby Brit-Car-Nut » Thu 15.09.2016, 22:25
Looks right to me.
Your second picture (other posting) shows that you don't have that installed... Just 2 loose bolts visible
Postby lotusflasherman » Thu 15.09.2016, 22:29
You need a bracket to join the bolts I've marked red to the wastegate bolts I've marked yellow.
Postby lotusflasherman » Thu 15.09.2016, 22:35
Here is my bracket in place.... just taken this but I'm not removing the heatshield just to take a photo! :lol:
Postby esprit888 » Fri 16.09.2016, 01:06
Brit-Car-Nut wrote:Looks right to me.
Me too, in your pic you can just see the 10mm threaded hole which is to attach the heat shield
esprit888
Postby Grampy » Fri 16.09.2016, 07:36
Cheers guys you are stars.
:bowdown:
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Postby simonbuk » Fri 23.09.2016, 11:34
So what's happened ?!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby clemo » Fri 23.09.2016, 21:13
Grampy wrote:I hate turbos :bonk: :banghead:
quote of the day .
clemo
Postby Grampy » Mon 26.09.2016, 12:13
Sorry guys all in and ready to fire. Just need to change the oil and filter (don't want old oil in the turbo) also need to tighten the dip stick tube (bitch to get to) day off Thursday so we let you know.
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Postby Grampy » Thu 29.09.2016, 10:53
Well it started first turn of the key. There was a squeeling noise and it looks like the alternator belt is too tight. Turned it off as it started to smoke :shock:
Very mixed feelings
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Postby Grampy » Thu 29.09.2016, 12:23
Siezed alternator. Fixed with wd40 and a hammer
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Postby simonbuk » Thu 29.09.2016, 12:46
So whats happening - are you going faster ??!!
Was the wastegate ported as you bought one of the performance chips ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Grampy » Thu 29.09.2016, 13:56
Still a few things to do Simon but it's running. It's ported to 22mm no chip yet
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Dipstick
Postby Grampy » Fri 30.09.2016, 10:12
How do you tighten the dipstick After removal to replace the turbo. I just can't get a spanner in it :banghead:
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
