MBV, Everest Chip, Both? What have I got?
Re: MBV, Everest Chip, Both? What have I got?
Postby Dom » Wed 04.10.2017, 14:25
The plug chaser worked and the 02 sensor is niw seated niceky. Thanks for the tip!
Dom
Postby Steve A » Wed 01.11.2017, 22:12
Dom wrote:The sensor finally arrived today and is now fitted, together with the correct chip from Alan. I got stung £15 by Royal Mail and it took longer to get 10 miles from Heathrow to my home than it did to get from America.
That's strange I didn't get stung :? I'm almost disappointed :-D
Postby Steve A » Sat 04.11.2017, 18:35
:? OK now I've started looking at this and have removed my chip ready to send it back to be modified, so it's full steam ahead.
Looking at the wiki instructions I have removed the half moon cover and wheel arch liner and yes I need to add the two wires necessary to make the sensor work.
Questions for those that have done it (please):
1. I'm assuming the best method of splicing the wires is soldering them ? (that's going to be fun at the ECU lots of access).
2. The wire D7 from the ECU, would that be a grey wire ? (just checking).
3. I've not found where the wiring comes through the bulk head into the drivers foot well, can it be seen from the half moon ?
( I'm doing this in the garage and I can only open the drivers door, just enough to get in :roll:)
Postby Dom » Sat 04.11.2017, 23:05
Steve, I was very lucky that all the wiring was there on my SE and it literally was plug and play, once I had installed the revised chip. Getting the bung out for the O2 sensor takes patience. I used a 50/50 mix of nail polish remover (acetone) and ATF to soak the area and a breaker bar to help 4emove the bung. I found a thread chaser was necessary to clean the thread to accept the O2 sensor fully. Overall, the job was an easy one and I am definitely seeing improved economy. Sorry I can’t help with your wiring queries, but I’d still say it’s a job worth doing. Make sure you use the correct socket to fit the O2 sensor, as it could get damaged if you’re not careful.
Dom
