LGM/Ekapol Intake Pipes
Postby abmunro » Mon 21.04.2008, 16:58
Where have people plumbed the BOV exhaust into.
Straight into air box?
Is there a hole or do we need to drill one
Paul P..... do you pics of exhaust pipe fitted yet.
Tony
abmunro
BOV
Postby woody » Mon 21.04.2008, 18:06
I've connected mine directly into the side of the airbox with a plastic 22mm elbow from B&Q.It's very tight, and means cutting about 1" off either end of the 90 deg Samco hose.Connected the elbow on the inside of the airbox with a 22mm plastic lock nut.Be careful not to drop the lock nut into the intake pipe like I did !
Cheers,
Woody
woody
Intake Pipe
Postby woody » Wed 23.04.2008, 09:50
Tony,
No.
Take the new pipe from the BOV around the back of the Engine, and connect it with the tee piece to the short length of black pipe from the overboost transducer to the vacuum connection on the plenium.( a short length of 3mm black rubber pipe that is about 200mm long) Cut this pipe in the middle, and fit the tee piece
Cheers,
Woody
woody
Postby ailwyn » Wed 23.04.2008, 09:54
Tony,
The only pipe I know of that heads in that direction towards the windscreen at the L/H corner is the washers.
I have plumbed mine into the hose that goes from the other end of the plenum to the boost transducer.
Ailwyn
Interior Trim
Postby woody » Wed 23.04.2008, 11:04
Tony,
It does not sound like the right hose.Look to the front of the Plenum, and on the LH side corner is the vacuum pt with a black hose connected to the Overboost Transducer bolted onto the wing.
Cheers,
Woody
woody
Postby abmunro » Wed 23.04.2008, 11:54
OK
It's sorted now
Thanks guy's...
I have not yet connected recirc up yet so my car sounds CHAVTASTIC... :-D :-D :-D
but will be soon remedied... :D
abmunro
Postby ailwyn » Wed 23.04.2008, 12:54
Just to let everyone know I've not forgotten.
PMs to Paul.P, ABMunro & Woody will be going out shortly.
RogerF, and AB2CV, I'm finding out the postage costs this week, so may as well wait until their on their way and pay me the VAT + Postage the same time.
The spare black hoses will be heading to the US by the weekend hopefully.
1st BOV list:
1. Paul P: whole kit w black samco -- PAID -- Delivered
2. ab2cv: whole kit w blue samco -- PAID -- Pending UK Delivery
3. Enright: pipe kit w black connectors -- PAID -- Pending Dispatch from the US
4. Dunnlor: whole kit w black samco. -- PAID (+$2) -- US Delivery
5. A B Munro: whole kit w blue samco -- PAID -- Delivered
6. Ailwyn: whole kit w black samco -- PAID -- Delivered
7. Algirdas: whole kit w black samco -- PAID -- US Delivery
BOV run # 2
1)woody : Samco black fittings,adaptor, re-route, and Greddy BOV. -- PAID -- Delivered
2)Dean G : Black or blue, Samco fittings,adaptor, re-route, Greddy BOV -- PAID
3) Rogerf : Red Samco fittings,adaptor, re-route, and Greddy BOV. -- PAID
4) HIBUTK: Black Samco fittings, adaptor, reroute and Greddy BOV.
5) MattRI: Green (or Yellow) Samco fittings, adaptor, reroute and Greddy BOV -- PAID
6) Peter: Black Samco fittings, adaptor, reroute and Greddy BOV. -- PAID
7) drasicjazz: Blue silicone fittings, adaptor, re-route, and Greddy BOV -- PAID (Belgium address)
BOV run # 3
1)White91elan : Samco black fittings,adaptor, re-route, and Greddy BOV
2)MattDon : Samco red fittings,adaptor, re-route, and Greddy BOV
Postby Ekapol » Sat 26.04.2008, 22:44
Coming your way
-- picture from iphone --
Peter: You could just call us to schedule for the installation.
Ailwyn: Thanks for the summary and helping out.
Ekapol
bov run 2
Postby Rogerf » Mon 28.04.2008, 17:42
Hi Ekapol,
I presume they're the Samco hoses boxed in the picture as i've just received my BOV and pipe via Ailwyn this morning.
Also noticed the address which is being sent to Mr Gibbons which is not a problem as i work with him.I'll just worn him to expect a parcel soon!
Regards,
Roger
Rogerf
Postby Rogerf » Mon 28.04.2008, 17:47
Oops that should of been a pm! :oops:
Nevermind i'm sure you will read it soon enough Ekapol!!
Roger
Rogerf
Postby Enright » Tue 29.04.2008, 12:18
I couldn't believe that the parcel turned up yesterday, so seeing as I'm on holiday anyway I got busy and installed the pipe and valve.
Re: bov run 2
Postby Ekapol » Tue 29.04.2008, 23:36
Rogerf wrote:Also noticed the address which is being sent to Mr Gibbons which is not a problem as i work with him.I'll just worn him to expect a parcel soon!
Regards,
Roger
Yes, red hoses are going your way.
I noticed that before we shipped out too. So the address was edited right there at the carrier to go to your correct address that I have on file :-)
Ekapol
Postby ailwyn » Tue 29.04.2008, 23:43
Enright wrote:I couldn't believe that the parcel turned up yesterday, so seeing as I'm on holiday anyway I got busy and installed the pipe and valve.
So how about some info on how you mated the bailey to the LGM pipe?
Postby Enright » Wed 30.04.2008, 07:56
Ah, that was very simple but effective - I built up 3 layers of bicycle inner-tube on the Bailey's pipe and forced the two together. Hope it holds!
Postby Monty » Wed 30.04.2008, 18:20
Neil,
Have you got your DV on the right way round? just doesn`t look right :?
Postby Candles » Wed 30.04.2008, 19:16
Candles
Postby Enright » Wed 30.04.2008, 21:40
Oh, OK. :oops:
It didn't come with any instructions and I figured it was like an air operated solenoid valve. Easily fixed - thanks guys. :D
Postby Monty » Wed 30.04.2008, 22:52
Enright wrote:Oh, OK. :oops:
:smt044
Postby Paul.P » Thu 01.05.2008, 16:41
abmunro wrote:Where have people plumbed the BOV exhaust into.
Tony
Tony, i had to get a 135 degree pipe with longer legs made to plumb my recirculating outlet into the trashcan, but it has fitted real nice in the end. I used a wc outlet connector ( 25mm ) to use as a connecter from trashcan to pipe.
Postby Ekapol » Thu 01.05.2008, 18:48
Paul.P wrote:Tony, i had to get a 135 degree pipe with longer legs made to plumb my recirculating outlet into the trashcan, but it has fitted real nice in the end. I used a wc outlet connector ( 25mm ) to use as a connecter from trashcan to pipe.
Looks like a job well-done :smt023
Ekapol
