Overboost
Re: Overboost
Postby Steve A » Thu 21.07.2022, 22:37
:clap: Good investigative work there Trev, :cheers:
Re: Overboost
Postby TrevorB » Wed 03.08.2022, 18:56
OH NO! Problem back. Took 'Merlot' for a drive tonight and was going fine even pushed it for my outward drive and everything good but that intermittent problem came back on the return journey. I'm not even really pushing just a gentle throttle increase until I reach 4000 rpm and then boom the dreaded overboost. Frustratingly she drives beautifully outside of this issue. Back to the drawing board, think porting the wastegate may now be needed.
I'm now away for a couple of days but on Sunday I will do the 'paper clip' test to see what codes are stored in the ECU. Then get back in touch with MSC next week.
Will update you as soon as I have any more information.
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Re: Overboost
Postby Tuga2112 » Thu 04.08.2022, 12:52
Trevor,
have you made sure the boost solenoid valve rod moves freely in both directions ? i know its the first thing to look at,but sometimes people forget the obvious, i'm wondering if there may be some rust getting it stuck but only sometimes ? which would explain why only after heating p the engine and cooling a little made it happen.
I had that issue on mine many moons ago, and i used sandpaper to get rid of the rust and brake fluid to "lubricate" the rod. (i know, not the right fluid, BUT its a very heat resistant fluid, and what i had at hand back then) and the issue with the valve never returned in 7 years.
Re: Overboost
Postby TrevorB » Thu 04.08.2022, 14:28
Tuga2112 wrote:Trevor,
Whereabouts is this rod? Or are you talking about the wastegate wiggle?
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Overboost
Postby Tuga2112 » Thu 04.08.2022, 15:15
yes, im talking about the wastegate wiggle XD i forgot the comon name for it
Re: Overboost
Postby TrevorB » Sun 07.08.2022, 11:31
Completed the 'paper clip' test and codes 24 and 33 are indicated:
24 Vehicle Speed Sensor
33 Manifold Absolute Pressure Sensor (High voltage / Low vacuum)
Is there anything I can do to resolve these issues, although I very much doubt it with my lack or mechanical expertise, or what can I tell MSC tomorrow when I ring them?
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Overboost
Postby TrevorB » Sun 07.08.2022, 12:32
HOW FRUSTRATING!
Took 'Merlot' for a drive just to confirm problem still there. Yes, you've guessed it. No problems on this drive. What am I supposed to do with this annoyingly intermittent problem?
Ahhh!! Grrrrr!! :banghead: :bonk:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Overboost
Postby Tuga2112 » Mon 08.08.2022, 14:20
TrevorB wrote:What am I supposed to do with this annoyingly intermittent problem?
check for ground wires badly connected maybe ? im just throwing guesses here, but intermittent flaws generally go in that direction :smt102
Re: Overboost
Postby Fredjohn » Mon 08.08.2022, 14:30
Surely you know the answer Trevor....give it another polish!
:D :D
Re: Overboost
Postby TrevorB » Tue 09.08.2022, 13:24
Tuga2112 wrote:check for ground wires badly connected maybe ? im just throwing guesses here, but intermittent flaws generally go in that direction :smt102
Spoke to MSC and they want the car back to investigate further. I mentioned the above and they will look at all options.
Can't get her in just yet as I have some shows to go too.
Take care
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Overboost
Postby Tuga2112 » Tue 09.08.2022, 14:08
Trevor,
do you get any dashboard lights flickering when this happens ?
Re: Overboost
Postby TrevorB » Tue 09.08.2022, 14:19
I do look at Engine Management light but NO nothing shows. Obviously working because I did 'paper clip' test.
It's very strange as so intermittent. I'll be taking her out again sometime this week so we will see if it reoccurs.
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Overboost
Postby Tuga2112 » Tue 09.08.2022, 14:26
ive had an intermitent issue after the head gasket change which was giving odd behaviour of the car while driving, under unpredictable circustances it would "choke" flicker the dashboard lights in the samer maner they do when you first plug the key, and then it would proceed to operate as normal.
i eventually found out there was a grounding wire at the rear of the engine that was not attached properly. (the bolt was not snug enough and every now and then with the engine vibrations it would completely cut off power to the ECU
not exactly the same symtpoms with exception that it was unpredictable, and performance related, but i guess also worth a look maybe ?
Re: Overboost
Postby Bryan M » Tue 13.09.2022, 18:15
I have an overboost issue with my car - it has been into Unit 4 and had the wastegate checked - it looks to be a standard exhaust and Gav & I can't tell if it has been chipped but it goes like stink up (keeps getting faster and faster) until it cuts out and the EML light comes on - it is difficult to tell where the revs are as the rev counter goes on holiday from time to time
Gav reckons a new hall sensor may help - any thoughts or how do i check if it has been chipped?
Bryan M
Re: Overboost
Postby Richmmm » Tue 13.09.2022, 19:20
Elanscan will report the MEMCAL version on one of the first lines, ie 9929, 9930, 1499.
Not sure if the mountain chips changed this identifier number.
Rich
Richmmm
Re: Overboost
Postby Rocklobster » Tue 13.09.2022, 21:21
Sounds identical to mine when I bought it. It does sound like your wastegate isn't opening. If it's been checked and you're sure it's free, it may be worth checking that the actuator is doing its job. It tells you how to check it in the Service Manual, it's quite easy.
Pete
Success is the ability to go from one failure to another with no loss of enthusiasm.
Rocklobster
Re: Overboost
Postby TrevorB » Wed 14.09.2022, 08:03
'Merlot' is going back to Maidstone Sports Cars today as despite all the other work which has been done over the past month, which has been explained on the LEC Facebook page, the overboost problem still exists.
I appreciate all the advice and help and will mention the various possible fixes that have been suggested.
I did another paper clip test the other day and since disconnecting battery and running car the only fault code apparent is 24 - Vehicle Speed Sensor, MSC know about this. I get NO engine Management light when problem occurs and like the other problem it is very intermittent.
I am hopeful that the problem will finally be resolved.
:cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Overboost
Postby texas2201 » Thu 15.09.2022, 16:01
I have an SE and years ago had the overboost problem.... this was after fitting the Peco exhaust and Everest chip and 02 sensor. Fixed by reaming out the Turbo from 16 to 21mm
Re: Overboost
Postby TrevorB » Mon 17.10.2022, 17:35
TrevorB wrote:'Merlot' is going back to Maidstone Sports Cars today as despite all the other work which has been done over the past month, which has been explained on the LEC Facebook page, the overboost problem still exists.
:cheers:
After 3 weeks in MSC hands they have contacted me today to tell me that there is a crack in the wastegate housing and they have sent the whole turbo off to a specialist for repair. Fingers crossed for a successful resolution. It's going to be another 3 weeks of anxiety whilst they hopefully fix the issue.
What are the experts thoughts on fixing a crack in the wastegate housing :?:
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Users browsing this forum: Apple [Bot] and 1 guest
