knoxmotorsports wrote:Small update:
The ID of Steve's exhaust system is 2.25", so this V2.0 is finished in 2.25" pipe, with 1.5" for the wastegate. By request in the future, we will be making them with 2.5" outlets and could probably even figure out a way to go 3" if someone had a need.
We will be adding the bracket for the support mount. And the wastegate discharge pipe is isolated with a flex bellows so it will not crack.
The exhaust bits for Steve's project are ready to go off to Swain for White Lightning coating. Inside and out on KnoxStiffy V2.0, outside on manifold and turbine housing, which are both ported.
At the track day at the end of a run, the oxygen sensor bung on the stock downpipe was 849*F the turbo center section 220*F. Compressor housing 125*F with 87*F and 99* track. We'll consider that a baseline to shoot for in terms of overall temperature reduction with our Stiffy.
knoxmotorsports wrote:...
As for O2 sensor placement, we put it there because that is the stock location, as bolt-on parts purchasers do not generally like to cut and splice/extend wires, especially for critical engine sensors. It doesn't make a difference if it is sampling from the entire system or solely from the turbine discharge, as the content of O2 present does not change as it flows through the turbo and manifold. It changes in the combustion chamber, from a more or less complete burn, more or less timing, etc.
racerstev wrote:I think you will find that the manifold is not a problem with a turbo this small. There can be huge gains after
the turbo like you are finding but very little before. I plan on logging backpressure before the turbo on
mine this year, I'm betting on a 2 to1 ratio boost vs backpressure. So 10 pounds of boost and 20 pounds
of backpressure.
Steve
GeoffSmith wrote:Phil, there may be different issues to the KnoxMotorSport's masterpiece on RHD cars without the front crash structure, so a UK equivalent would probably have to end up slightly different.
If Phil can get Piper interested, would you be willing to help in getting it off the ground Billy?
ccb056 wrote:Sorry to resurrect a 1 yr old thread but I did some searching and couldn't find anything.
Are these downpipes available for purchase?
