my actuator rod is the problem...please help...
Postby Luke - the elanimal » Thu 12.07.2007, 15:24
Hello all,
I think ive posted this in general too by mistake so sorry if youve read it but....
My problem isnt to serious apparently so im happy :lol:
My actuator rod has snapped off at the wastegate end, so its one of those that i will be needing (plus about four bolts or something) does anybody know where the best place for me to source a part like this from please?
Ive been told the job and part wont be tooo expensive by a good friend that diagnosed the problem so all i need to do now is find my rod lol :lol:
oooh i might actually be able to feel my babies full force soon enough it may seem :wink:
look forward to reading your suggestions guys.
all the best.
cheers guys i'll check back again soon.
Luke - the elanimal
Postby Russc » Thu 12.07.2007, 15:32
funnily enough i`ve just recently had the same sort of problem.
When i rang around i was told that you can`t get an actuator without a turbo unit. Therefore it`s a bit expensive.
Luckily enough Monty came to my rescue on this occasion but i did almost sort out a couple of alternatives.
1 was that SJ Sportcars thought they may be able to source me one
2 Forge will make you one, however i had problems fitting one of those to the bracket and fit in line easily.
Russc
Postby Luke - the elanimal » Thu 12.07.2007, 17:27
Russc wrote:funnily enough i've just recently had the same sort of problem.
When i rang around i was told that you can't get an actuator without a turbo unit. Therefore it's a bit expensive.
Hi thanks for that ..... who is Monty, and who are forge please? i will find out if i can get it mended locally but if not i'll look into these guys you have mentioned.
All the best.
Luke - the elanimal
Postby Luke - the elanimal » Thu 12.07.2007, 17:28
Luke - the elanimal
Postby Russc » Thu 12.07.2007, 18:00
Monty is a helpful lad on here who had an actuator lying around.
Forge are a motorsport part manafacturer, they make al sorts of things. Amongst these are actuators.
Luckily they also manafacturer parts for actuators including rods and turn buckles!!! I didn`t realise this until i looked at their site fully.
However i don`t think the lotus part is servicible. The link is here for details of what they make
http://www.forgemotorsport.co.uk/conten ... talog=0001
this is the one they can make for you http://www.forgemotorsport.co.uk/conten ... FMAC49CUST
I`m reliably informed that if you want them to make one the spring should have an opening pressure between 0.45 and 0.5bar.
Russc
thanks
Postby Luke - the elanimal » Fri 13.07.2007, 00:18
thanks ever so much....i will definately be looking into that, however today i found out i have a performance car mechanic friend who's dad has a proper auto workshop in his garage with welding gear and alllsorts!! its there life long hobby, and they are also able to fabricate small parts so theyre going to have a look on saturday for me. :lol:
The guy seems to think its relatively simple and theyll have it done for me by saturday night all being well, so i cant believe my luck....they dont even want payment as they love doing things like this :shock: :D (though i'll be sorting them out to say thanks either way)
i shall let you know how it goes after the weekend tho and if it isnt sorted i shall be using the guys from the website link u sent me.
thanks again i'll keep you posted. :wink:
Luke - the elanimal
Users browsing this forum: ludo and 1 guest
