by Tex » Sat 24.04.2010, 17:07
Frustration! Beautiful smooth power delivery on moderate boost, but as soon as full boost comes on line when engine is warm the power goes and it feels as though the engine has cut out. Management light come on and stays on for several minutes along with much reduced power. Any ideas?? Tex
Tex
by GeoffSmith » Sat 24.04.2010, 18:21
Probably wastegate related: If you've fitted a larger exhaust then you will need to port it. If not then it's probably stuck over the Winter and you need to wiggle it. Check out the
Wiki for details of both.
- Kitty Fiddler
by DavidW » Mon 26.04.2010, 13:17
sounds exactly like what happened to me a month or so ago...
viewtopic.php?f=37&t=16711
DavidW
by Tex » Mon 26.04.2010, 17:08
Thanks forthe advice. Was concerned the problem may have been electrical but as the car is very little used (and pampered) seems the wastegate is a good shout. Just moved to Poole in Dorset and am not confident - and very time poor - to do this. Anyone recommend a good place to help with this and general servicing stuff??
Tex
by dermotbell » Fri 30.04.2010, 07:34
Try
this area as this is where people winge or compliment garages.
Dermot
Dermot Bell
dermotbell
