by abmunro » Fri 07.05.2010, 09:29
I am picking up my car after having work done, Do these hours sound reasonable from garage
Fit injectors 3 hours
Remove Gearbox, fit clutch, fit quaife & re-install Gearbox 11 hours
Fit new LGM Turbo Kit 5 hours
Tony
abmunro
by Monty » Fri 07.05.2010, 10:03
The injectors are fiddley but should be less than 3 hours.
The gearbox has to be stripped to install the quaife so that will be time consuming, btw get them to check the end nut on the 5th gear section as i`ve heard these coming loose.
The 5 hours for LGM kit sounds good to me.
so what was the final bill
- Chunder King!
by Dico » Fri 07.05.2010, 14:50
Sounds fairly reasonable to me. Injectors maybe a little on the high side, but as Murph said the LGM turbo install sounds very reasonable.
Just for your interest- Quaife fitted mine for £125. I delivered and collected my box but they were happy to have it delivered and re-deliver it.
- Fool Boy Four - Founder
by abmunro » Fri 07.05.2010, 15:03
Its done and paid for now..
I was just checking tha I wasn't having my eyes taken out.
Thanks for info Guys
Tony
abmunro
Users browsing this forum: ludo and 1 guest
